Author Topic: Short 184, Aeroclub, 1:72  (Read 41881 times)
Re: Short 184, Aeroclub, 1:72
« Reply #45 on: April 11, 2015, 11:27:55 AM »
Well, I bit the bullet and went ahead with the oils! First gave the decals a light coat of Flesh base as per Uschi's instructions, then the oils. The first attempt wasn't too good so I dipped the brush in the thinner, brushed it off, and did it again. Much happier with the result now...
It's still not as good as I think it could be, but it'll do. Let's face it, there's not too much grain or colour difference visible in 1:72 anyway, so I really don't want to overdo the effect.
« Last Edit: July 04, 2017, 12:19:00 AM by IanB »
Offline Danh4
« Reply #46 on: April 11, 2015, 12:12:17 PM »
Ian,
I love the work you're doing on this, I'm watching and learning.  Those floats look fantastic with the oils on, I'm going to have to look into getting some of those decals and find a place to use them.
-Dan
« Reply #47 on: April 11, 2015, 10:44:49 PM »
It is so beautiful, Ian.
« Reply #48 on: April 11, 2015, 11:03:09 PM »
Thanks guys!
This appears to be one of those rare cases where the pic actually looks better than the real thing! I think I need a softer brush for future use, just to get rid of the paint lines (they're not too obvious, but I know they're there) and make it all blend a little better.
Offline Thumbs up
« Reply #49 on: April 11, 2015, 11:14:19 PM »
Hi Ian,the perfect tool for painting wood grain is a small fan brush,works a treat. :)
Offline malaula
« Reply #50 on: April 13, 2015, 12:02:25 AM »
Nice wood grain ,Ian!
« Reply #51 on: April 13, 2015, 02:28:55 AM »
Very interested in the wood grain as I am about to attempt the same with the floats on mine. I am thinking of just using primer and oils - it will be interesting to compare results. As you say in God's Own Scale there would be very little grain visible. Yours does look good to me.
« Reply #52 on: May 10, 2015, 11:53:26 AM »
After 3 weeks the oils were still tacky, and I didn't like them at all, so it's all been stripped off. I'm really not too happy with Uschi's decals in 1:72 so I probably won't be using them again. All they do is show lines which really aren't visible at all in this scale. Adding to that, after scouring the DF over and over again, I'm not even sure that the floats were made of wood - there are a couple of pics which clearly show rivets and chipped paint around the edges...so I will paint them the same grey as the struts and cowling - or maybe not...... :-\
On another note, a little more progress has been made on the wings. After an initial primer coat, I decided to fill the small indents for the strut locations and reposition them correctly. I've also separated the ailerons and added pins to remount them. I was going to add the float struts at this stage as the kit supplied items fit into slots under the fuselage which would need to be filled before painting, but then I discovered that both the PE and the white metal ones are way too long, (according to the DF plans) and too wide to fit with the mods I've made to the wings to enable them to be mounted folded. So.... I will make new struts and add pins to fit them - which will mean I will either have to drill the white metal float mounting bars, or make new ones of those too. Since they have a curve in the middle for the torpedo mount I may experiment with drilling them.....
 More fun to follow....thanks for looking in!
« Last Edit: July 04, 2017, 12:19:16 AM by IanB »
« Reply #53 on: May 11, 2015, 12:30:14 AM »
Nice update Ian.
« Reply #54 on: May 12, 2015, 06:40:56 AM »
It reads as though you are having some right old fun and games with this one! I still think that it will turn into a first class model in your very capable hands and will be very interesting with the wings folded.
« Reply #55 on: May 12, 2015, 11:04:48 AM »
Thanks, Martin and LM - indeed I'm having way too much fun with it. Each new challenge is more thought and another different solution....hopefully the solutions will work! LM - thanks for the vote of confidence!
« Reply #56 on: May 14, 2015, 11:43:46 AM »
Not much to show in the way of progress, but all the locating holes have now been drilled for the wing struts and the float mountings. Next up will be another coat of primer to check for any more filling/sanding that's needed, then adding the underwing shadow details for the roundals and ribs.
« Reply #57 on: May 14, 2015, 04:35:46 PM »
Nice job Ian.
1:72 isn't for the faint hearted!
« Reply #58 on: May 14, 2015, 10:03:26 PM »
It is a pure hard-core modelling! I am keeping my fingeres crossed!
« Reply #59 on: June 10, 2015, 12:33:41 PM »
I've been really busy with work recently, but I managed to get a little more done today. Spars and ribs have been added with a brown "Sharpie" and I attempted a first coat of CDL today. I tried ModelMaster Acrylics for the first time and thinned with Tamiya  thinner - it totally bunged up the airbrush! I now have 3 bunged up airbrush tips which are soaking in thinner to try to clear them out, I can't even get any air through them! So I went to my local hobby shop and bought Modelmaster thinner, maybe it's the Tamiya thinner....
Here are the tail surfaces and upper wing centre section ready for paint...
and here is the fuselage, CDL on and the nose painted too...
Now to sort out the paint problem....
« Last Edit: July 04, 2017, 12:19:37 AM by IanB »
