Author Topic: Encore 1/32nd SE5a 56 Squadron: 4891 JTB McCudden  (Read 64959 times)
Re: Encore 1/32nd SE5a 56 Squadron: 4891 JTB McCudden
« Reply #150 on: June 28, 2015, 09:23:00 PM »
Enjoy your time off, Rick my friend!  I'm looking forward to seeing
what surprises you have in store for us with the SE5 as work
resumes. :D
« Reply #151 on: July 01, 2015, 09:17:20 AM »
A small update. I have decided to use decal strips for the rib tapes. After application I added some simulated nail heads. This process takes longer than I thought, about 2 1/2 hours on the upper wing.
se5a 006 by Richard Geisler, on Flickr
se5a 007 by Richard Geisler, on Flickr
se5a 010_crop by Richard Geisler, on Flickr
PS: The width of the tapes was based on the WNW SE5a.
« Last Edit: July 01, 2015, 09:23:35 AM by RAGIII »
« Reply #152 on: July 01, 2015, 09:24:28 AM »
Very fine work on the ribs, Rick!  I know just how tedious that can be, having done much the same thing on my Eduard Tripe.  Whew!
« Reply #153 on: July 01, 2015, 09:38:35 AM »
Rick,
    What did you use for the nail heads? It certainly did the job.
« Reply #154 on: July 01, 2015, 09:56:32 AM »
Lovely work on the ribs and nail heads Rick.
« Reply #155 on: July 01, 2015, 10:35:45 AM »
Thanks Bud, I figure I only have about 6 or 7 more hours to go to finish the rib tapes  ::)
Thanks also to Lance and Des! Lance, I used one of those wheels with points that my memory just can't recall the name of at this time. For fabric and leather work I think.
« Reply #156 on: July 01, 2015, 10:40:38 AM »
Those should really look the part Rick once paint is applied .  8)
« Reply #157 on: July 01, 2015, 12:14:05 PM »
  Thanks Rick, I have several of them but, like you, can't remember what they are called!  :-[
Offline iwik
« Reply #158 on: July 01, 2015, 03:57:53 PM »
Hi!
Can't wait to see what those rib tapes will look like under the paint.
Keep it up!
Iwik
« Reply #159 on: July 01, 2015, 04:26:19 PM »
Interesting. I wonder, what will be the final effect.
Offline IFF1418
« Reply #160 on: July 01, 2015, 06:42:08 PM »
This is so nice Rick my friend. Getting better and better! Keep up the great work!
Kind regards
Patrick
Offline Pgtaylorart
« Reply #161 on: July 01, 2015, 09:24:54 PM »
Are these the Archer rib tapes and stitching?
George
« Reply #162 on: July 01, 2015, 10:40:54 PM »
Przemol,
I am not sure that the small nail head impressions will be visible after a couple coats of sealer and paint. If not then just having the tapes is more than was there in the beginning  :-\
George
Geaorge,
Not Archer just decals... actually the rib tapes from my 1/24th scale Marcos Fokker DVII trimmed to width. The nail head effect is just my usual smoke and mirrors. I do have one set of Archers product but decided against them. The reason is that I figured I would need 3 or 4 more to do the wings on this one.. costly and would add wait time to the build.
« Reply #163 on: July 01, 2015, 10:45:27 PM »
Thanks Terri! I hope it works out well.
Hi!
Keep it up!
Iwik
Thanks Iwik. Like I said above the tapes will certainly be visible as an improvement over nothing. I wanted an effect that was just a bit more subtle than the WNW SE tapes. Hopefully it all will be good.
Kind regards
Patrick
Patrick my friend, I always appreciate you following my builds and your encouragement! I wonder what you and Ernie are cooking up to amaze us?
« Reply #164 on: July 01, 2015, 11:30:53 PM »
Terrific work on the rib tapes, Rick!  As you and Bud mentioned,
tedious work, but the result is so good! As for Patrick and my
present project, I am bound by the official secrets act...mon ami. ;) ;D
  As always, I'm looking forward to your next update, Rick. :D
