Author Topic: SSW D IV conversation  (Read 13651 times)
Re: SSW D IV conversation
« Reply #45 on: February 11, 2015, 07:17:56 AM »
Thank you Des.
I will do the same for the D III if the fuselage is paint.
« Reply #46 on: February 11, 2015, 10:33:52 AM »
Thank you very much Terri and Patrick.
Terri It is a very smal different for the wing cord. I sanded this little different.
Thanks for the reply back Martin , you did one very fine job on the sanding  ;D
« Reply #47 on: February 12, 2015, 07:13:04 AM »
There is no probleme Terri.
The bigger different is the wing span.
Offline BigBlue
« Reply #48 on: February 13, 2015, 06:10:01 AM »
Looks great, Martin!
Offline Sarcococca
« Reply #49 on: February 13, 2015, 07:07:36 AM »
A very remarkable conversion.
Well done so far.
« Reply #50 on: February 13, 2015, 10:34:30 AM »
Thank you very much Chris and Sarcococca.
« Reply #51 on: February 27, 2015, 03:19:51 AM »
The top wing grounded and on underside take Aviattic Lozenge.
« Reply #52 on: February 27, 2015, 04:21:11 AM »
The fuselage and lower wings primed white. After drying, the body is primed dark brown and the metal portions provided with aluminum paint.
For the wood I use HGW the dark decals.
« Reply #53 on: February 27, 2015, 04:54:23 AM »
Looking good, Martin!
« Reply #54 on: February 27, 2015, 06:31:03 AM »
Thank you Bud.
« Reply #55 on: February 28, 2015, 08:34:05 AM »
The next little update with new decals.
The air intakes will paint alu colour.
« Reply #56 on: May 02, 2015, 07:36:02 AM »
The engine requires some refinements.
The valve stem is made of brass wire and the ignition cable must be attached.
The hood and the engine mount has been thinned out and painted.
« Reply #57 on: May 02, 2015, 11:56:34 PM »
Nice too see you back on this one Martin  :)
« Reply #58 on: May 03, 2015, 02:35:43 AM »
Hi Terri,
I have about 1 week for the D III early and D IV to go on with the build.
« Reply #59 on: May 03, 2015, 08:20:15 AM »
Martin,
Like Terri said you are making great progress! I am looking forward to your next update!
