Author Topic: SSW D IV conversation  (Read 13551 times)
« on: January 17, 2015, 04:09:10 AM »
It will be the plane from Vzfw Karl Bohenkamp Jasta 22.
I make parallel to my D III early an D IV conversation.
I use there for the Koster SSW D IV, the new Eduard SSW D III overtrees, Aviattic 5 colour Lozenge, and from Karaya SH III and LMG 08/15.
Most of parts are use from Eduard.
« Last Edit: January 17, 2015, 04:16:38 AM by radio »
Re: SSW D IV conversation
« Reply #1 on: January 17, 2015, 04:16:48 AM »
I am looking forward to this one Martin!
« Reply #2 on: January 17, 2015, 04:19:28 AM »
Rick it will be very nice to follow my thread.
Offline Dirigible-Al
« Reply #3 on: January 17, 2015, 04:23:32 AM »
Hi Martin
I am sure this will be a great one to follow.
Alan.
« Reply #4 on: January 17, 2015, 04:26:38 AM »
Thank you Alan.
Offline petrov27
« Reply #5 on: January 17, 2015, 04:44:44 AM »
Another very interesting conversion - following along!
-Patrick
« Reply #6 on: January 17, 2015, 04:46:02 AM »
Thank you Petrov.
« Reply #7 on: January 17, 2015, 02:53:06 PM »
i have a few of those kosters they really arent bad. have fun with your new project
« Reply #8 on: January 17, 2015, 09:43:51 PM »
Thank you Albatros.
Offline dtomko
« Reply #9 on: January 17, 2015, 10:48:08 PM »
Another great project, Martin.  I didn't realize the Koster wings were resin.
Drew
« Reply #10 on: January 18, 2015, 12:37:13 AM »
Thank you Drew.
You are right they are resin.
« Reply #11 on: January 18, 2015, 05:58:49 AM »
Here I have now also started.
Covered the handles on the inside and glued the first parts in the body parts.
Seatback provided with several holes and mounted on the motor side openings extravagance.
« Reply #12 on: January 19, 2015, 05:45:55 AM »
Lower wings of the hull sawed off parts of Koster and Eduard kit and ground.
Next parts glued into the fuselage halves, floor, front bulkhead and belt box on the upper fuselage.
Then everything primed inside.
« Reply #13 on: January 21, 2015, 07:23:24 AM »
Here I have got on a little bit.
The left and right fuselage side is almost ready. In addition, the throttle control with linkage is right.
Also the cockpitfloor is almost ready. In the front wall the tank and rear engine holders with carburettor part is right.
The upper front body part are still absent the MG `s.
« Reply #14 on: January 26, 2015, 03:01:53 AM »
The fuselage sides and floor is ready.
The air pump and pipeline are new made from brass parts.
