Author Topic: Help with Polyimide Tubing Size  (Read 2135 times)
Offline prepcik
« on: January 17, 2015, 02:56:23 AM »
What is the right inside diameter size for polyimide tubing for 1/32d scale rigging lines?   I have a source but the sizes are given in fractions of an inch.   Given the cost for the tubing, I'm reluctant to experiment.   The smallest size listed had inside diameter of 0.0050 inches.
Any recommendations would be most appreciated.
Offline eclarson
Re: Help with Polyimide Tubing Size
« Reply #1 on: January 17, 2015, 04:22:06 AM »
Funny you should ask!  I just got my order of this today, purchased for that very reason (1/32 turnbuckle bodies).
http://www.amazon.com/gp/product/B000FMWU2E
In Metric, the ID is 0.32mm and OD is .47mm.
Des' article on making turnbuckles suggests 0.5mm brass tubing with an ID of 0.3mm.  The poly tubing I got was the closest to those sizes I could find.
http://www.ww1aircraftmodels.com/page8.html
You've got to shop carefully as the prices vary wildly.
Eric
« Reply #2 on: January 17, 2015, 05:14:23 AM »
It depends on what diameter line you are using. 30 AWG works nicely with .12mm line, it's too small for anything bigger. I use 29 AWG for the .14mm "Worlds Best Rigging line" stuff that Steven was dispensing awhile ago.
Offline Pgtaylorart
« Reply #3 on: January 17, 2015, 06:35:17 AM »
Perfect timing and thanks for the info. I just placed an order on Amazon.
George
Offline prepcik
« Reply #4 on: January 17, 2015, 07:57:32 AM »
Bo and Eric,
Thanks, greatly appreciate the advice.
