Under Construction
1/32 Roden Albatros D.I conversion to D.II (Mvr)
Pages:
3
4
5
Topic: 1/32 Roden Albatros D.I conversion to D.II (Mvr) (Read 11200 times)
Ssasho0
Re: 1/32 Roden Albatros D.I conversion to D.II (Mvr)
Reply #15 on:
February 12, 2015, 07:48:52 PM »
thats some excellent modelling, hats off and I will be chekcing your thread regularly
Think globally, act locally!
lcarroll
Reply #16 on:
February 13, 2015, 01:04:32 AM »
The interior detailing is magnificent, this is exceptional work!
I'll be following your progress closely.
BigBlue
Reply #17 on:
February 13, 2015, 06:13:06 AM »
Wow, Rahmi, that looks really lovely! Nice photos as well.
Sarcococca
Newbie
Reply #18 on:
February 13, 2015, 07:10:54 AM »
Wow!
What an eye for details! Absolutely terrific work.
I like your attention for details! Great job adding all nuts on the tank surface and the engine upgrades are incredible!
coyotemagic
Reply #19 on:
February 14, 2015, 02:16:58 AM »
Spectacular work on the interior and framing, Rahmi! Up to your usual high standards.
bud
WarrenD
Guest
Reply #20 on:
February 14, 2015, 02:24:03 AM »
It's looking really great so far Odysseus.
Odysseus
Jr. Member
Reply #21 on:
February 17, 2015, 01:28:46 AM »
Thanks to everyone! Here are some new progress photos.
The fuselage closed. I will add some details and fix errors after oil paint work completed.
See you next update
Rahmi
coyotemagic
Reply #22 on:
February 17, 2015, 05:35:53 AM »
Extraordinary work on the guns and cockpit coaming, Rahmi!
Reply #23 on:
February 17, 2015, 05:38:16 AM »
Your cockpit padding looks excellent! The fit of the coaming to fuselage requires work but is not as bad with the forward cowls removed as you have done! Looking forward to more!!!
uncletony
Reply #24 on:
February 17, 2015, 07:22:05 AM »
Nice work! The long cocking levers though aren't appropriate for this machine -- they appeared much later. In fact many of the early Albatros D.Is and D.IIs carried MG08s (not LMG08/15s) so be sure to check your references if this kind of thing is important to you.
Cheers!
Youtube Channel
Odysseus
Jr. Member
Reply #25 on:
February 17, 2015, 08:47:15 AM »
Thank you all!
Thanks for the tip Bo, i will check and fix it.
RAGIII, i will open only left cowling part and working only visible section of the fuselage. I hope it will be easy
Ernie
"Once more into the breach"
Reply #26 on:
February 17, 2015, 08:56:09 AM »
Excellent work! The interior is really well done!
Ernie
Derrick
Full Member
Reply #27 on:
February 17, 2015, 09:28:12 AM »
The cockpit padding is that aluminum foil ? Curious how you did it. Thank you for any information.
Odysseus
Jr. Member
Reply #28 on:
February 17, 2015, 04:41:02 PM »
Thank you Ernie!
Derrick, i used self adhesive aluminum foil for that. Bought from local hardware dealer not model shops, this is cheap one.
compressor man
Jr. Member
Reply #29 on:
February 17, 2015, 10:29:43 PM »
Super work here! I have built a Roden Albatros, so I know what you are dealing with. Nice!
Pages:
3
4
5
Under Construction
