Author Topic: Morane-Saulnier Type AI 1/48 Special Hobby  (Read 24033 times)
WarrenD
Re: Morane-Saulnier Type AI 1/48 Special Hobby
« Reply #45 on: March 10, 2015, 11:33:55 AM »
I think it looks great Terri, I've never had any luck trying to brush paint Tamiya paints. What did you thin the red brown with for the wood grain effect?
« Reply #46 on: March 11, 2015, 08:54:15 AM »
Terri,
Sorry but I seemed to have missed this update. Your wood grain and cockpit are AWESOME!
« Reply #47 on: March 12, 2015, 09:48:38 AM »
Thanks guys ! I'm working on the side framing . Kit parts don't fit so this needs to be scratched and the lower part of the instrument panel interferes with this and I still need to paint the framing on the fuselage sides .
Warren , I will either use Tamiya X-20 thinner or their lacquer thinner . When ever I brush paint Tamiya paints I always dip the brush in thinner first . Really never had to many troubles with their brands .
« Reply #48 on: March 12, 2015, 11:02:04 AM »
Very beautiful work Terri.
WarrenD
« Reply #49 on: March 12, 2015, 11:34:23 AM »
Thanks Terri, I'll try their thinner next time. I guess I'm just too old school and remember dipping my brush in the paint itself with no problems. As a friend of mine put it once, Tamiya paint doesn't like itself.
Offline xan
« Reply #50 on: March 12, 2015, 08:38:02 PM »
yes, interior is very well done, congratulations
Xan
« Reply #51 on: March 12, 2015, 08:44:46 PM »
Really nice work on the wooden parts, Terri.  Like
Warren, I have not had much luck with the Tamiya
paints, but will try your method.  Thanks for the tip. :)
« Reply #52 on: March 17, 2015, 04:32:19 AM »
Thanks guy's ! ;D
Warren , Ernie . For about 6 years now I have been using Tamiya paints and other products and had to adapt to their behavior .
I used to use Testors Model Master paints but it is getting harder to find . Most shops now carry acrylic paints . I don't thin them either with water . I find that when spraying I don't get good atomization of the paint and will have some what a surface with a ruff texture .
Their lacquer thinner works very well with the acrylic line and you get a really fine smooth finish either brush or airbrush . Work with them and see what works best for you . They aren't every one favorite .
« Reply #53 on: March 18, 2015, 01:42:56 PM »
Progress report star date 1245.56.98.7
Holidays are a great way to spend it in front of the bench and computer ! I ended up looking online to see if I can find the profile for I don't recall the tail numbers and I didn't make a note of this . I did however found some wonderful pic's of this type ending in a few more details to be added . So much for out of the box !
The framework is not correct at the front of the cockpit , since this won't be seen I'm not worried about it . Rudder bar as toe straps and control cables . Throddle I made using plastic bits and PE from the parts pin . Hand pump was fashioned out of plastic rods as well as the control rods for the upper wing controls . Frame was relaced , kit parts don't fit and are over scaled . Trigger cables for the guns and that is it for the details .
Guns are also ready for their weathering once the paint has fully dried .
« Reply #54 on: March 18, 2015, 01:43:29 PM »
« Reply #55 on: March 18, 2015, 01:44:05 PM »
« Reply #56 on: March 18, 2015, 01:44:44 PM »
« Reply #57 on: March 18, 2015, 02:10:57 PM »
Lovely work on the cockpit tub Terri and the guns look very good, you are moving along quite well.
« Reply #58 on: March 18, 2015, 03:50:29 PM »
Great looking pit and MGs Terri!
« Reply #59 on: March 18, 2015, 11:22:42 PM »
Thank-you Des and Rick for the kind comments .  8)
Todays goal will be getting the fuselage button up and start the weathering on the engine and do some more work on my spitfire .
