Author Topic: Fokker AII 1/72 plans  (Read 1932 times)
Offline JamesAPrattIII
« on: December 17, 2014, 08:37:09 AM »
This is my first post I am looking for a set of Fokker AII 1/72nd scale plans. I am planning on doing a conversion to this kit and I really would like the correct wing measurement. Thanks in advance.
Re: Fokker AII 1/72 plans
« Reply #1 on: December 18, 2014, 10:27:43 PM »
James, I am looking through my books,. No luck so far but will let you know if I find something.
« Reply #2 on: December 19, 2014, 03:09:55 AM »
I also am wondering if the Windsock Fokker Compendium vol. 1 might have plans?
« Reply #3 on: December 19, 2014, 11:24:10 AM »
M.5 = Morane derived monoplane designed by Fokker
M.5L = M.5 long wingspan
M.5K = M.5 short wingspan
A.I = two seat M.5L
A.II = 1 seat M.5L
E.I = 1 seat M.5K + MG
Compendium vol 1 has A.I plans and E.I plans, but not A.II plans... However I think one could interpolate with the above in mind.
« Reply #4 on: December 21, 2014, 02:20:05 PM »
i think the "A" designation meant unarmed.also oldman did a build of a fokker a.1 converted from a revell eindecker last year. so ask him.
« Reply #5 on: December 23, 2014, 08:30:01 AM »
The Windsock Fokker Com Volume 1 does have the plans in 1/48 scale which isn't that much use to me since I only model in 1/72 scale.
« Reply #6 on: December 23, 2014, 09:20:12 AM »
Copy the 1:48 plans at 66.67% and you'll have 1:72 scale plans.
Offline Old Man
« Reply #7 on: December 23, 2014, 09:26:38 AM »
The A.II was the military version of the M.5L, and was designed to accommodate two people, though not in any great comfort: the pilot's seat was mounted on a bench, oriented fore-and-aft, and there was room on the bench behind his seat for someone else to sit, the whole arrangement being rather like two people on a motor-bike. It doubtless often was flown solo.
Here is a link to the build our Mr. Albatross mentioned above:
http://forum.ww1aircraftmodels.com/index.php?topic=2235.0
The A.I is a separate aeroplane, with the Fokker designation M.8.
http://www.flightglobal.com/pdfarchive/view/1915/1915%20-%200999.html
It had a much wider fuselage, high-mounted wing, and accommodated two men side by side, with extensive cut-outs in the cockpit sides for better downward vision.
I am away from my books, and will check when I can, but I think the Compendium had both 1/72 and 1/48 drawings. In any case, 1/48 drawings convert to 1/72 by a 33% reduction in size.
« Last Edit: December 23, 2014, 09:31:35 AM by Old Man »
