Hints and Tips/Questions about modeling
Instrument decal application
Topic: Instrument decal application (Read 2851 times)
David 63
Newbie
December 12, 2014, 12:53:30 AM »
Hello. This is my first post to this forum and I would like to know the best method for applying instrument decals. Should I leave the decal backing on and glue them in place or should I apply them as I would a normal decal?
David
Kreston
Sr. Member
Re: Instrument decal application
December 12, 2014, 01:21:22 AM »
Apply as a normal decal. I am very careful sliding them off the backing paper and into their proper position...they are so small you don't want them folding over on themselves.
uncletony
December 12, 2014, 01:23:47 AM »
i put a puddle of Micro Set on the model first where the decal will go. Then it is quite easy -- if you are careful -- to properly orient the instrument face by nudging it around gently with a tweezer...
By the way, welcome to the forum!
Youtube Channel
David 63
Newbie
December 12, 2014, 02:51:08 AM »
Thank you very much for the welcome and the answer. Have not made a ww1 aircraft for quite awhile. I think that about 50 years ago I built all of the old Revell kits but it's been ages. Your site is so informative and your knowldge base is quite vast so I had to get on this forum. Being the holiday season I have no builds at the moment but plans are to start the WnW Eindekker 1 in January. Thanks. David
coyotemagic
December 12, 2014, 03:12:23 AM »
Welcome to the forum, David! I do the same as Bo. I also add just the tiniest drop of liquid soap in warm water to reduce the chance of the decal folding over on itself.
December 12, 2014, 07:05:26 AM »
Well David, not much to add but another welcome! I use pretty much the same method as Bo and Bud. ( Just not as well as they do)
Des
Reply #6 on:
December 12, 2014, 07:44:13 AM »
I echo everything that has been said about the instrument decals but add my welcome also.
gcn
Sr. Member
Reply #7 on:
December 12, 2014, 05:17:45 PM »
And make sure you have a sheet of Airscale cockpit decals handy for when the inevitable happens
stefanbuss
Reply #8 on:
December 12, 2014, 07:25:22 PM »
After the instrument decal has set, I apply a drop of Humbrol clear cote to represent the instrument's glass.
Stefan
Nigel Jackson
Reply #9 on:
December 12, 2014, 07:48:19 PM »
I think that RB's advice to trim off as much of the surrounding clear film is very important where you need the decal to sit smoothly in moulded, raised bezels.
