Author Topic: starting WNW FE-2b early  (Read 4591 times)
Offline robvd
« on: November 30, 2014, 05:32:30 PM »
Finaly,
today I am starting to build the FE-2B from WNW as an tribute to  my passed friend.
It will be big challenge  because it is the first WW1 kit for decades to be build by me.
But also I want to add every Buckle and other details that are around so that I present the finished model to his widow.
I will try to place some photo's from time to time(if I can figure out how)
I would like to know if there is a site where I can detailed info about the FE-2B esepecialy about the placement of the buckles etc.
I can use any help as a rookie in this field.
I know that this kit is not the easiest with all that  rigging etc so I hope that I will be succesful.
Offline KitRookie37
Re: starting WNW FE-2b early
« Reply #1 on: November 30, 2014, 06:24:08 PM »
Hello to all,
If you need supporter, I follow your build log.  ;)
Best regards.
Alain.
Use the force, Luke.
Offline Jamo
  • Wellington, NZ
    • My Smugmug album
« Reply #2 on: November 30, 2014, 06:52:14 PM »
Hi Robvd
I have taken many photos of the two FE2b aeroplanes from The Vintage Aviator Ltd. Here are links to my albums over at Photobucket which might be helpful to you
http://s1011.photobucket.com/user/Jamo_kiwi/library/FE2b?sort=6&page=1
http://s1011.photobucket.com/user/Jamo_kiwi/library/FE2B%20bomber%20Jess?sort=6&page=1
http://s1011.photobucket.com/user/Jamo_kiwi/library/Beardmore%20160hp?sort=6&page=1
Lots of rigging photos in there  :)
James
Happy Modelling
James Fahey
Offline Ian from Doncaster
« Reply #3 on: November 30, 2014, 07:16:25 PM »
Hi Robvd
James
I second that!  James' shared resources are great especially for engine detailing.  You can also try TVAL themselves, again they thankfully post much of their project work online.
http://thevintageaviator.co.nz/projects/fe-2b/building-fe-2b
Also, a search on here for Fe2b will bring up various build logs.
This kit makes a stunning model.  It looks daunting with all that rigging, very open cockpit and structure, engine etc - however taken in stages it is not as hard as first looks.  The wing rigging, is relatively simple to do - just loads of it and care needs to be taken to get the lines all in the right place.
With the AM detailing you are planning to do, this is one build I will look to follow!
« Reply #4 on: November 30, 2014, 09:01:32 PM »
Robvd, I think that will be a lovely tribute to your friend.  Thankfully
there is enough information available to help you along.  I wish you
well in your build, and if you are to share it here, it will be a good one to
follow!
« Reply #5 on: December 01, 2014, 05:45:25 AM »
Watching a Fee coming together is always a joy and knowing the reason behind this project of yours makes it all the more so.  We're here to cheer you on, Rob.  There is no better source on WWI aircraft detail than Jamo's photos.  Make good use of them.  I know I will when I get around to building my Fee.  Thanks, James!
Offline robvd
« Reply #6 on: December 01, 2014, 08:05:20 PM »
Wow thank you all for the informatione and all the kind wordsand all teh other help  it gives me extra  inspiration  for this project
THANK YOU :)
Offline robvd
« Reply #7 on: April 06, 2015, 04:14:22 PM »
After a long sick leave due to my surgery I am finaly able to start the build again.
« Reply #8 on: April 06, 2015, 04:28:53 PM »
I hope you have recovered well from your surgery Rob and now I look forward to seeing you start work on your Fee, I have this kit in my stash so will be watching closely.
Offline rhwinter
« Reply #9 on: April 06, 2015, 05:13:01 PM »
Hi Rob,
did you see this one here? Might be of help for your build, too.
http://www.windsockdatafilespecials.co.uk/the-fe2b-flies-again-278-p.asp
There have been more datafiles around (e.g. see here: http://web.ipmsusa3.org/content/raf-fe-2b-war-windsock-datafile-147), a quick research on the Internet will bring them all up..
Best regards, Richard
Offline Brad Fallen
« Reply #10 on: April 06, 2015, 09:29:46 PM »
Hi Robvd
I've just finished the late version of this kit and it's fabulous. Lots of work, but no real 'gotchas' - follow the instructions (and use plenty of references - James' photos are wonderful), and you'll have no real probs.  cheers Brad
« Reply #11 on: April 06, 2015, 10:17:38 PM »
Nice to have you back after your surgery and I hope all is well
on that front. :)  I look forward to seeing your restart of the Fee
which I will be following with great interest.
« Reply #12 on: April 07, 2015, 01:35:29 AM »
I am looking forward to following your build. Your inspirational reason for building this bird will make it even better to follow along.
Offline BigBlue
« Reply #13 on: April 09, 2015, 10:31:44 AM »
Glad you are back on your feet, Rob.  I too look forward to watching this build.
