Author Topic: super glue applicator cleanup tip  (Read 2467 times)
Offline Todd Holaday
« on: November 29, 2014, 03:38:53 PM »
I just recently read a tip that was helpful to me and am passing it along.  The super glue applicators routinely sold are basically a paint brush handle with a protruding metal end like a needle with the eye end notched.  I'm sure you know what I'm referring to, either you have one or have made one.  I have struggled with not being able to wipe away the excess glue in time to avoid a buildup occuring.  I had been scraping off the hardened excess and occasionally have broken an applicator.  Here's the tip.  Keep a candle nearby and very briefly use the flame to burn off the excess.  Works like a charm, keeps the applicator clean and its so fast the needle doesn't heat up and become brittle.  :)
Re: super glue applicator cleanup tip
« Reply #1 on: November 29, 2014, 03:59:40 PM »
Thanks Todd for the tip, I'm sure this will be very useful for those who use the needle eye applicators.
Offline hiddeous1973
« Reply #2 on: November 29, 2014, 04:30:20 PM »
I use that mehtod as well, just keep in mind that burned super glue is toxid, so keep away from the smoke and keep well ventilated. I have a collection of needles in handles and burn them of in a batch under the kitchen ventitator or outside if the weater is good. Needles are cheap and I seem to go through small paint brushes very quickly so my set of aplicators gets bigger every year!
WarrenD
« Reply #3 on: November 29, 2014, 11:30:15 PM »
Yep, I use a small, disposable lighter. I'm too much of a danger to myself and others to keep a lit candle on the workbench.  ;) :o :o
« Reply #4 on: November 29, 2014, 11:38:54 PM »
I keep my applicator (needle stuck into a wine bottle cork) with the tip soaking in a small jar of acetone. Always ready, no muss, no fuss.
Offline jknaus
« Reply #5 on: January 09, 2015, 12:03:45 PM »
Ditto for me to clean the tip. I use a lighter. Also before I saw that these items were being sold I used to make mu own applicators. Some sewing needles nicked from my whif and inserted into a piece of brass tubing with a round tooth pick jammed in to hold the needle in place. Then cut off the tip of the eyelet. I had a few different sizes so I could use whatever amount of ca I needed, e.g. small tip for small quantity in tight area up to a medium tip for filling. When the eyelet finally broke it was easy to remove the wood jam and pull the needle out and replace it.
James
