Author Topic: Ques. about detailing a Mercedes D.III engine  (Read 2247 times)
Offline compressor man
« on: November 22, 2014, 11:13:42 PM »
Hi guys,
I am just starting a Roden Albatros. The D.III engine in the kit is only ok so I am going to further detail it. What is typically done with the tube that runs down the side of the engine that contains the plug wires? Do most people use tiny tubing (what size?) or simply drill holes here and there in the kit parts?
Re: Ques. about detailing a Mercedes D.III engine
« Reply #1 on: November 22, 2014, 11:41:21 PM »
.8mm brass tube is about correct in scale:
« Reply #2 on: November 23, 2014, 01:17:20 AM »
Thanks bo. And that engine is absolutely incredible!
Offline davecww1
« Reply #3 on: November 23, 2014, 02:09:21 AM »
Bo does it the correct way, 1/32 nd the size of the actual aircraft, but a simpler way that I use is to use a solid plastic Evergreen Styrene rod.  Then I just bend the wires and glue them to the plug and the bottom of the tube with superglue.  Works very well in 1/48 scale and would be more than passable in 1/32 if you are leaving the cowling closed.
Offline nmroberto
« Reply #4 on: November 23, 2014, 03:20:42 AM »
Bo,  what do you use for the plug wires?
Robert
« Reply #5 on: November 23, 2014, 04:36:38 AM »
Wire and insulation material from an old pair of earbuds.
Offline Fokker boy
« Reply #6 on: November 23, 2014, 04:51:12 AM »
Taurus makes some cool details for these engines as well, I'll be using some on the WNW Mercedes I'll be dropping into my D.III, along with the Barracuda intake pipes.
« Last Edit: November 23, 2014, 07:05:28 AM by Fokker boy »
Kevin
« Reply #7 on: November 23, 2014, 06:51:19 AM »
Thanks for all of the helpful replies. I just had a thought. Whoever came up with the forum for "Specific aircraft build links" had a really good idea. I would love to see something like that for articles and step-by-steps where people have super detailed the various types of engines. A good engine can really make a model.
Des, are you reading this? ;)
« Last Edit: November 23, 2014, 10:16:41 AM by compressor man »
« Reply #8 on: November 23, 2014, 09:22:55 AM »
Surf through the Fokker DVII group build threads - plenty of good engine detailing ideas in those.
Starting with the Baron's :)
« Reply #9 on: December 22, 2014, 08:01:46 AM »
Well, thanks to the advice and encouragement received here I have detailed that Roden engine. Wow, those valve springs are really, really small!
mike in calif
« Reply #10 on: December 22, 2014, 10:06:24 AM »
That looks pretty good as well.
