Author Topic: WNW AMC DH2 24 Sqn. Major Lanoe Hawker VC  (Read 59882 times)
Offline LukasTheLight
  • Addicted to Wingnuts...
Re: WNW AMC DH2 24 Sqn. Major Lanoe Hawker VC
« Reply #120 on: January 03, 2015, 08:57:58 PM »
Hi Lance!
Loving your work!!! Those Aviattic decals look terrific!!! And I'd never seen using your post-shading technique before but damn that looks good!!! :)
Are those decals transparent??? I mean could I do classical pre-shading with some results? :)
Cheerio
Lukas
Lukas
Offline IFF1418
« Reply #121 on: January 04, 2015, 12:38:12 AM »
Wonderful work Lance (as usual my friend). The wings looks teriffic as did your interior. Keep up the great work my friend! She will be gorgeous.
Kind regards
Patrick
Offline BigBlue
« Reply #122 on: January 04, 2015, 01:31:27 AM »
Lance, your build looks really lovely.  The linen effect looks fantastic, and even the touch up spots seem to add realistic character (even if they are not visible to the naked eye).  I'm taking notes!
Online lcarroll
« Reply #123 on: January 04, 2015, 06:14:25 AM »
Thank you for the positive comments, Chris, Patrick, Lukas, Ernie, and Rick. As always they make my day. Lukas, as Richard indicates the versions with Clear backing are transparent, I would say basically identical to the Clear Backed lozenge. I only Post Shaded on this one however I believe Pre-Shading would work very nicely.
Offline drdave
« Reply #124 on: January 04, 2015, 07:21:32 AM »
I don't know how I've missed this! Super work mate. I'd been wondering about the aviattic linen. Now I'm sold.
« Reply #125 on: January 04, 2015, 01:11:25 PM »
Hi Lance!!!
I thought that was the case but wasn't sure :) thanks Richard and Lance!!! Great work!!!
Cheerio
Lukas
Lukas
« Reply #126 on: January 04, 2015, 08:22:18 PM »
Good job Lance!
I didn't know about the linen decals - look great - that's another project for me to try! ::)
Online lcarroll
« Reply #127 on: January 05, 2015, 12:09:11 AM »
Thank you Dave, Lukaz, and Guy. The "Linen" decals have added a new dimension to this one, I'm looking forward to getting the various bits assembled  into one subject to see the overall effect.
Offline stefanbuss
« Reply #128 on: January 05, 2015, 09:18:30 PM »
Incredible. You are correct, your touched up paint looks rather ugly - my main point of concern would be the loss of the beautiful linen structure underneath.
The nacelle is simply lovely. Nothing more to add.
Stefan
« Reply #129 on: January 06, 2015, 02:05:21 PM »
Terrific work and effect !!1
Offline Edo
« Reply #130 on: January 06, 2015, 07:28:10 PM »
hi Lance!
great build going on! I'll grab some ideas for my build.... I particularely like the scheme you are choosing, and the realization is simply amazing!
I am experimenting with a "glue and cloth" method to replicate canvas surfaces, I'll let you know how it goes ...
ciao
edo
« Reply #131 on: January 06, 2015, 10:44:52 PM »
This is shaping up beautifully Lance.  I'm looking forward to completion. ;D
Online lcarroll
« Reply #132 on: January 07, 2015, 12:01:36 AM »
Stefan- as I said earlier the "green" patches shown by the camera are really hard to pick out under lights or natural lighting, unless it's just my old eyes coming into play. I 'm going to leave it as is, if any change is required I'll use the white backed PC10 you sent to me to simulate a couple of repairs, Richard.
Bob & Ed - Thank You, much appreciated.
Edo, now that's interesting...........   curious to see how that works out.
Online lcarroll
« Reply #133 on: January 20, 2015, 09:27:41 AM »
    I've finally made some progress, got all the buckles drilled in and installed ( 110 on the wings and fuselage alone) and the lines attached to the lower wing. It's a little "busy"!
    Sorry for the poor quality photo, kind of looks I was seeing after that marathon!
Next step was mounting the struts. I elected to install the cabanes and the inner bay wing struts, adding the outer bay mains after the upper wing was installed. The two grey damaged spots on the lower wing are where I "pinged" off the brass tube fairleads installed previously for the aileron control cables, they'll be replaced later. The wing edges are taking a real beating from the constant handling during the rigging process, it will all need touching up further on in the sequence. I used my standard quick template to align the cabanes, especially handy as I'd broken one of the mounting lugs off a rear one and lost it! :-[ >:(
   Once the upper wing was mounted the outer bay main struts were popped into place and CA'd.
   As you've probably noticed this Build no longer represents Hawkers 5694. I rather elected for 24 Squadron's B Flight 6011, shot down and captured on 11 July 1916 and well represented in the Data File as it had the specific scheme I wanted. The fuel line from the overhead aux. tank will be plumbed in later in the build.
    Presently I'm up to my ears in rigging this little devil. She looked like a demented bunch of Lilliputians had run amok with some spools of mono before, now with each line completed and trimmed she looks better as the process goes on. I'm using a combination of rigging plans from the Kit Instructions, the excellent tutorial on Bob's Buckles Website, and the Data File three views along with numerous photos; there are contradictions present in the mix, particularly on the cabanes but the majority wins............
     This Kit is not for the Beginner nor faint at heart however it's doable with patience and pre-study at the various steps. I certainly wouldn't want to attempt it in a smaller scale, as the man said in the movie, "I'm really getting too old for this ........."! ;)
Michael Scarborough
« Reply #134 on: January 20, 2015, 10:54:59 AM »
Doesn't look as if you're too old to me, Lance.
Admirable, to say the least.
Bon courage,
Michael
