Author Topic: Copper State Brandenburg W 12  (Read 43912 times)
Re: Copper State Brandenburg W 12
« Reply #60 on: November 11, 2014, 07:45:52 AM »
Brilliant work, Martin!  She's looking fantastic.
« Reply #61 on: November 11, 2014, 09:00:08 AM »
Thank you very much Bud.
« Reply #62 on: November 15, 2014, 02:30:13 AM »
After some days something new.
It goes on in the engine.
Valve springs from 0. 2 mm of copper wire finished.
Fuel pipe from brass wire made and with carburettor and filter linked. Throttle control with spring and connecting rod made.
Side tail unit and horizontal tail unit finished.
Lower wing to fuselage glue.
The first spatulas work carried out.
« Reply #63 on: November 15, 2014, 04:42:31 AM »
Engine work continued, cable excursions and various other pipes rightly.
In addition pictures of the fuselage with wing, front upper cover only in the mood.
« Reply #64 on: November 15, 2014, 10:22:01 AM »
I like your details Martin  :) I have this kit in the stash and the cockpit/cowling doesn't even come close on the fit . Not and easy kit and you are holding your own , good job so far Martin  8)
« Reply #65 on: November 15, 2014, 10:25:58 AM »
Brilliant work, Martin!  She's shaping up very nicely.
« Reply #66 on: November 15, 2014, 08:50:43 PM »
Thank you for your compliments Terri and Bud.
« Last Edit: November 16, 2014, 05:11:56 AM by radio »
« Reply #67 on: November 16, 2014, 12:03:04 AM »
Martin,
You are certainly moving right along on this build! Nice work on the engine details!
« Reply #68 on: November 16, 2014, 05:12:24 AM »
Thank you very much Rick.
« Reply #69 on: November 16, 2014, 05:32:31 AM »
Admittance side of the engine wide-built.
« Reply #70 on: November 16, 2014, 10:39:22 PM »
Thumbs up Martin  8)
« Reply #71 on: November 17, 2014, 01:05:27 AM »
Thank you Terri.
« Reply #72 on: November 17, 2014, 06:09:51 AM »
The induction pipes and ignition cables to the spark plugs are ready.
The ignition cables to the distributors have stuck to the protective box.
The rocker arm holders are glued to the engine.
« Reply #73 on: November 18, 2014, 06:25:34 AM »
Okay after the release from WNW and download the instruction I must take some changes.
There are colour changes and aditional to the cockpit.
The fuel filter is glue and paint.
The MG goes back and higher.
To the disturber the first ignition wire glue.
« Reply #74 on: November 18, 2014, 08:49:05 AM »
Excellent progress, Martin!  Looking forward to the next update.
