Author Topic: Yet another WnW F.E.2b.  (Read 15780 times)
Offline Pete Nottingham
Re: Yet another WnW F.E.2b.
« Reply #30 on: June 22, 2012, 02:56:43 AM »
N.C.S.E.
I see you have put the curved piece behind the pilots seat ok, how did you do it?  As it seems to be causing some people problems.
Pete.
Offline N.C.S.E
« Reply #31 on: June 22, 2012, 05:23:43 PM »
Hmm, it may have something to do with the late vs early thing as the late 160 HP engine has 3 holes for extracooling for the radiator, that may have something to do with it as it is a different piece with maybe a slightly different and more difficult fit. I simply put it in one side of the fuselage and pushed it into the other side that, with liberal application of glue before putting it in. I wasn't confident about the fit between the two parts, it appeared to have a gap, but looking at the instructions it seemed to be alright, as well as the model on the WnW website.
The years to come seem waste of breathe, a waste of breathe on balance with this life, this death. - W.M.Yeates
Offline Ian from Doncaster
« Reply #32 on: June 22, 2012, 05:30:10 PM »
I too am not too concerned about the slight gap between the curved panel abd the nascelle halves - the gap will be a little less the tighter the halves fit, but I haven't got that far yet.  Yours looks just fine to me :)
What are you using for rigging material?
« Reply #33 on: June 22, 2012, 05:34:53 PM »
I tried your method Ian, it has yet to be perfected by me, but its the best paint job I've done, thanks!
You're welcome - looking forward to some more pics.  I have learned so much from the contributors on here and that's the great thing about forums like this, everyone is open to sharing experiences and techniques.
Offline N.C.S.E
« Reply #34 on: June 30, 2012, 10:37:28 PM »
Alright, first the bad news news, I buggered up the wing texturing as I tried further experimentation which failed horribly, but now I have moved onto the rigging with my brand new rigging wire, it's very good after using simple thread for rigging, the elastic really helps to give the wire tension, contrary to what I've read here I've found it does increase the strength of my wings, most of rigging is completed now.
« Reply #35 on: July 01, 2012, 02:36:21 AM »
You can always sand off or strip unwanted paint?
Offline Dal Gavan
« Reply #36 on: July 01, 2012, 12:40:41 PM »
You're doing some lovely work, mate, and making mistakes is just another way of learning so I wouldn't be too hard on yourself.  As Ian says, you may be able to clean off the areas you're not happy with.  Some Isopropyl alcohol on a cotton bud/ Q-tip will allow you to selectively clean off the paint and won't attack the plastic.
Keep up the good work, I've enjoyed reading your build log.
Dal.
Offline N.C.S.E
« Reply #37 on: July 03, 2012, 01:17:35 PM »
A lot of modelling done in the last few days.
The struts are as usual a bit wonky but the rigging is much better I think.
I have yet to put more coats on the top plane, so the paint job isn't the best there yet.
I'm thinking about using the same colour on the top wing to repaint the bottom planes.
« Reply #38 on: July 03, 2012, 10:47:04 PM »
You have made huge strides in your building and you were pretty good to start with!!!! Each project is a step forward. Well done so far!!!!
« Reply #39 on: July 04, 2012, 12:42:52 AM »
She's progressing nicely, will be an impressive model when done for sure.
« Reply #40 on: July 04, 2012, 05:52:01 PM »
I couldn't agree more, well done.
Pete.
« Reply #41 on: July 16, 2012, 03:51:32 AM »
Wow!  You've certainly gotten a lot done on her, my friend.  She's coming along brilliantly.
« Last Edit: July 16, 2012, 03:53:45 AM by coyotemagic »
Offline Whiteknuckles
« Reply #42 on: July 16, 2012, 09:56:16 AM »
Nicely done NCSE, good job on rigging the beastie. Keep it up!
Eternal Apprentice
« Reply #43 on: July 16, 2012, 11:05:14 PM »
   NCSE,
Moving right along nicely my young friend. It's very enjoyable watching you progress to date.You've come a long way in a short period of time and it's wonderful to have watched your skills grow.Keep up the outstanding work young master in training.
Offline N.C.S.E
« Reply #44 on: July 28, 2012, 11:15:56 PM »
I always make it a rule to leave the model in a better state then it was when I came to it.
But I must admit the rigging is my destroyer, the fiddly control wire rigging is the death of me, I go to do it and if I put it in place, then some other wire snaps off, if another wire doesn't snap off, then the one I've just placed snaps off, argh!
