Author Topic: Curtiss Hydroaeroplane  (Read 60037 times)
Re: Curtiss Hydroaeroplane
« Reply #210 on: December 31, 2014, 08:51:18 AM »
She belongs in a museum, Des  ;)
Stunning workmanship and execution.
A massive WELL DONE!  :)
vB
What else can I add?  Wow!
Well one more to add to the above !!!!
WarrenD
« Reply #211 on: January 02, 2015, 01:51:51 AM »
Wonderful work Des!
« Reply #212 on: January 03, 2015, 05:56:46 AM »
This is typical…. just as I was away the master builder returns to the bench. A belated welcome back Des and as the others have written, WOW!!!!!
That is truly another masterpiece and no mistake.
« Reply #213 on: January 03, 2015, 06:43:38 AM »
Thank you Ed, Warren and LM for your very kind comments, they are very much appreciated.
Offline Royston
« Reply #214 on: January 03, 2015, 03:36:57 PM »
she's a work of art,
really like the way you have attached the struts.
Roy
« Reply #215 on: January 05, 2015, 10:13:50 AM »
Thanks Roy for your nice comments.
Progress continues albeit at a slow pace. I made the tail booms from brass tube and soldered the joins, makes for a quite strong assembly. I also made the tail plane and elevators plus the rudder, these are made from styrene sheet with Bob's Strippers as the frame and ribs, still need to do some shading before it all goes together.
« Reply #216 on: January 05, 2015, 10:47:18 PM »
Looking good Des  :)
« Reply #217 on: January 06, 2015, 12:32:45 AM »
Nice clean looking soldering Des.
« Reply #218 on: January 06, 2015, 02:36:04 AM »
Very great Des.
« Reply #219 on: January 06, 2015, 08:05:18 AM »
Many thanks to Terri, Michael, Chris and Martin for your very kind comments.
Chris, I think I am starting to get the hang of this small soldering technique, having the soldering station with a fully variable temperature control is a great help, and also having low heat solder with silver and some heat activated flux all add to making the job quite simple. I'm still in the learning stages but getting better with each job I tackle.
I have done the shading on one side of all the tail components, this time I used pastels. This is the first time I have used them for shading and seeing the results that Lance gets gave me the inclination to try it. I am really happy with the results and the process is certainly a lot easier than the painted method, this is a system I will be using more often. Thanks Lance  :) :)
Offline eindecker
    • Models In Scale
« Reply #220 on: January 06, 2015, 12:09:50 PM »
A few years ago when I was enamoured with armor modeling, I got Tony Greenland's "Master Class" volume — a very useful treatise for all kinds of modeling — in which Tony explained and extolled the use of pastels for subtle effects. I have used them extensively and agree. They are easier to use and more forgiving than paint.
Michael Scott
Offline sobrien
« Reply #221 on: January 06, 2015, 10:43:30 PM »
Des, is there a tutorial anywhere on the soldering technique? Or could you do one? Your work continues to amaze me. I wish I had the time and patience.
Sean
Online lcarroll
« Reply #222 on: January 07, 2015, 12:14:40 AM »
Des.....  a very small "return" on all the tips and motivation you've provided here the past several years, and in all fairness I learned the technique from a "Master" here, are you listening, Bud??
« Reply #223 on: January 07, 2015, 09:53:08 AM »
Outstanding work as always des! Your tail surfaces and booms look awesome!
« Reply #224 on: January 08, 2015, 01:05:39 PM »
I took a few more tiny steps today. I made the two wing tip floats and painted them, they have now been fitted to the bottom wing tips.
