Author Topic: Revell 1/72 Dr.I  (Read 2958 times)
Offline Stuart Milliken
Revell 1/72 Dr.I
« on: September 01, 2014, 11:41:38 AM »
I just completed this model yesterday, and while there are aspects of it I could have done better on, I think it may be of interest because of a technique I tried for the "Fokker streaking."
I first painted the surfaces a fairly light tan, and then masked and sprayed angled stripe of various widths and spacing.  I then clear coated this with Future.  The streaking was then done using Winsor & Newton 'Olive Green' artist's oils with a stiff rake fan brush. I found that after an initial application, it worked well to wait about a half an hour and rake it again.  This produced better defined streaks.
The painted on diagonal stripes had two benefits: (1) they provided variation in color and apparent density for the streaking without needing to achieve that by the streaking process itself, and (2) they provide a consistent guide for the direction of streaking.
In retrospect, I think it would have been better to use greenish rather than brownish colors for the diagonal stripes.  Also, as you may notice, the oils bled a bit under the masking for the leading edge; I had left the masking in place until the oils dried, and should have removed it early on to clean up the bleed through.  Oh well, next time.
And by the way, this new-tool Revell kit is quite nice!
Stuart
Re: Revell 1/72 Dr.I
« Reply #1 on: September 01, 2014, 12:27:14 PM »
Nice job! It looks as though your streaking method worked very well. Definitely one to be proud of.
« Reply #2 on: September 01, 2014, 12:31:06 PM »
You did an amazing job with the Dr.1 Stuart, the streaking is very well done, this is a very nice looking  model and one that I would be proud to have sitting on my display shelves.
« Reply #3 on: September 01, 2014, 01:11:49 PM »
Beautifully done, Stuart.  Your streaking is superb.
« Reply #4 on: September 01, 2014, 05:41:34 PM »
Once more - beautifully executed, but larger photos would be welcome.
« Reply #5 on: September 01, 2014, 11:48:29 PM »
I agree with my Amigo! The streaking looks fantastic!
« Reply #6 on: September 02, 2014, 03:24:28 AM »
Agreed , a trifecta from the 3 Amigos .
« Reply #7 on: September 02, 2014, 04:10:21 AM »
That streaking looks very convincing and thank you for describing so well how you achieved it. The model overall is excellent too. I did not know that Revell had retooled this rather old kit.
« Reply #8 on: September 02, 2014, 07:59:04 AM »
Lovely work on this little kite  :)
Offline Epeeman
« Reply #9 on: September 02, 2014, 08:03:58 AM »
Lovely DR1, Stuart!
Streaking looks pretty good to me and, yes (I've built this one) this latest little Revell kit is an excellent model.
Offline vincentm
« Reply #10 on: September 02, 2014, 09:46:13 AM »
Same as the others: the streaking appears very realistic, though it's certainly not easy (I haven't tried yet). I also like the warmth of the wood color on the prop.
