Author Topic: 1:48 Roden Fokker D.VII (Jasta 21)  (Read 40988 times)
Offline Fokker boy
Re: 1:48 Roden Fokker D.VII (Jasta 21)
« Reply #135 on: August 01, 2012, 06:06:50 AM »
Thanks again folks. I'm a bit behind my projected schedule to complete this, but perhaps by the end of this coming weekend it'll be in the RFI section, or at least I hope so.
Kevin
« Reply #136 on: August 01, 2012, 11:19:31 PM »
  Kevin,
A little behind or not she's still an excellent project my old friend. Although I don't build much in 1/48 myself I've learned much about the quirks of building a Roden Fokker from you. Thanks for all the outstanding heads ups,so if I do build one of these kits I'll know what to watch out for. After this Fokker is complete is there any possibility of bringing back your wonderful 1/28 scale project from LSP and the Aerodrome ?
Offline Fokker boy
« Reply #137 on: August 02, 2012, 02:28:58 AM »
I don't know Greg, I made several errors that I later discovered. Nothing that couldn't be easily undone, but I was also having really bad problems with the lozenge (purchased from Doug), on that one. At least I finally figured out that the rib tapes can be ordered directly from Microscale. They may not be exact width needed, but at least they have a good color selection. We'll have to wait and see on that one I guess. I wouldn't rule it out as a possibility.
« Last Edit: August 02, 2012, 03:30:02 AM by Fokker boy »
Kevin
Offline Fokker boy
« Reply #138 on: August 05, 2012, 12:41:29 PM »
I almost forgot to do the ailerons,... this has now been addressed.
Kevin
Offline Fokker boy
« Reply #139 on: August 05, 2012, 12:44:53 PM »
OK, once again, I had mislaid the prop for the last week or so. Found it tonight and continued with faking in some wood grain.
Kevin
Offline Fokker boy
« Reply #140 on: August 05, 2012, 12:47:57 PM »
Remainder of lozenge has been added to wing area between fuselage haves, and is ready for clear coating.
Kevin
« Reply #141 on: August 05, 2012, 12:49:54 PM »
  LOL Kevin tie some string to that thing. Careful hiding your own Easter Eggs may not be far away. Ecellent update my old friend and I look forward to more.
Offline Fokker boy
« Reply #142 on: August 06, 2012, 02:03:24 AM »
It's a problem I've been having for quite a while now Greg,... I'm forever misplacing things. For instance, I've lost the entire OOB decal sheet that has all the stencils for this machine, so I'm moving on without them. Working on ten or fifteen projects at the same time seems to be the root cause, and is something I'm going to have to resolve.
(For whatever it's worth, when Charles Metz passed away, I was approached with an offer to move into a moderator position on LSP, so I'm now officially LSP_Typhoonattack over there.)
http://forum.largescaleplanes.com/index.php?showtopic=40149
Kevin
« Reply #143 on: August 06, 2012, 05:53:07 AM »
  " I was approached with an offer to move into a moderator position on LSP, so I'm now officially LSP_Typhoonattack over there.)"
 Kevin,
Congratulations my old friend,I'll see you there.
Offline Fokker boy
« Reply #144 on: August 07, 2012, 11:52:51 AM »
The fun continues, this time with the tiny Master Spandau gun assemblies.
Kevin
Offline Fokker boy
« Reply #145 on: August 08, 2012, 10:32:55 AM »
One of the last items on my list, decal wise, is the cross on the tail,... decal is too short in two directions, so I had to add little bits at the upper and aft ends.
Kevin
Offline Fokker boy
« Reply #146 on: August 08, 2012, 12:05:53 PM »
Port side gets the same treatment.
Kevin
Offline Fokker boy
« Reply #147 on: August 08, 2012, 12:08:35 PM »
Axle wing gets some filth.
Kevin
Offline Fokker boy
« Reply #148 on: August 08, 2012, 12:13:29 PM »
The scary part,... plane (after applying a fairly heavy acrylic clear coat), receives a soft over-spray of dark gray. This will be wiped down with a damp brush to give some "character" to the model, (I hope).
Kevin
Offline Whiteknuckles
« Reply #149 on: August 08, 2012, 12:19:56 PM »
And she was looking all pretty and shiny ;D
Will be interesting to see the effect after the 'wipe down'.
This has (and still is) a great WIP - thanks FB.
Eternal Apprentice
