Author Topic: 1:48 Roden Fokker D.VII (Jasta 21)  (Read 41079 times)
Re: 1:48 Roden Fokker D.VII (Jasta 21)
« Reply #120 on: July 25, 2012, 06:39:05 AM »
what a looker kev.
« Reply #121 on: July 25, 2012, 10:08:00 AM »
  Kevin,
Beautiful work on the fuselage lozenge my old friend.As Scott said she's a real looker.
Offline Fokker boy
« Reply #122 on: July 25, 2012, 10:26:22 AM »
Thanks a bunch fellas, it's certainly trying my patience, that's for sure. Fuselage is essentially finished at this point, so work continues on the bits and pieces.
Kevin
« Reply #123 on: July 26, 2012, 12:38:53 AM »
An eye catching colour scheme. She'll look good when you have her finished.
« Reply #124 on: July 28, 2012, 04:58:48 AM »
Kevin,
    I looked back through your Thread and couldn't determine what brand of Lozenge you are using; what make is it and is it available in 1/32? (or Kit supplied?)
Offline Fokker boy
« Reply #125 on: July 29, 2012, 12:07:07 PM »
Kevin,
It's Techmod lozenge, but I don't think it's available in 1:32. Even if it was available, I would not recommend it, though others may disagree.
Kevin
Offline Fokker boy
« Reply #126 on: July 29, 2012, 12:21:49 PM »
To enable lower wing to be attached (Roden wing is too narrow to fit between fuselage halves), wing was cut in half (after grinding a slot across the width of it), and the slot filled in with CA and a small brass rod.
Kevin
Offline Fokker boy
« Reply #127 on: July 29, 2012, 12:28:00 PM »
Elevator has now been painted to match horizontal stab. The decals falling off continues to plague me. In this photo, several rib tape sections seemed to have stuck better to my fingers better than to the model.
Kevin
Offline Fokker boy
« Reply #128 on: July 29, 2012, 12:32:15 PM »
Rib tapes replaced/repaired on starboard lower wing, upper wing positioned to get a feel for the overall visual impact of the scheme.
Kevin
« Reply #129 on: July 29, 2012, 11:14:15 PM »
Kevin,
    It's not just Techmod that sticks better to your fingers then the model; I'm playing the same "game" with my WNW Lozenge and tapes although I believe it's complete now that it's oversprayed. The tapes were particularly frustrating, just part of the process I suspect! ::)
Hang in there, she's really looking good.
« Reply #130 on: July 30, 2012, 12:31:33 AM »
She looks great. As tedious as this sounds by any chance would a quick overcoat after each section of decals has dried avoid the lifting?
« Reply #131 on: July 30, 2012, 01:30:04 AM »
I really like this colourful scheme. I'm getting to be a big fan of lozenge.
Offline Fokker boy
« Reply #132 on: July 30, 2012, 08:19:24 AM »
Thanks so much for the comments folks. Yes, clear coating the decals should make a big difference, (I hope).
Kevin
« Reply #133 on: July 31, 2012, 10:28:42 AM »
it's a very attractive scheme indeed
Offline Whiteknuckles
« Reply #134 on: July 31, 2012, 11:58:47 AM »
She's going to look even more excellent than she already does Kevin. ;)
Great progress.
Eternal Apprentice
