Author Topic: Best epoxy glue or other?  (Read 1939 times)
guitarlute101
« on: August 28, 2014, 01:44:48 AM »
Hi everyone,
  I wanted to check in to see what you are using when you need to glue plastic or resin but need more time than super glue allows before it sets.
  I've been reading up on some 2 part epoxies but I wanted to see if anyone had any experience with any glues of this type.
Offline Umlaufmotor
Re: Best epoxy glue or other?
« Reply #1 on: August 28, 2014, 05:46:50 AM »
Hi Mark,
I used this one: --- Follow the link below..............
http://forum.ww1aircraftmodels.com/index.php?topic=3195.165
.......... and take a look to post replay No.170, the sixth picture.
Maybe this helps you
Servus
Bertl
guitarlute101
« Reply #2 on: August 28, 2014, 05:57:32 AM »
I found it Bertl.   Many thanks.    ;D
« Reply #3 on: August 28, 2014, 12:05:05 PM »
I use the same thing, Mark, only not nearly so skillfully.  I use the Loctite brand, readily available here in the states.
http://www.loctiteproducts.com/p/13/23/epxy_heavy/overview/Loctite-Epoxy-Heavy-Duty.htm
guitarlute101
« Reply #4 on: August 28, 2014, 12:07:44 PM »
Thanks Bud!
« Reply #5 on: August 28, 2014, 11:13:01 PM »
How easy is this to sand ?
I wonder if this would be a better substitute for filling seems rather then using a think super glue ...
« Reply #6 on: August 29, 2014, 01:36:15 AM »
I use both -- epoxy to position / initial assembly and then CA for strength.
@ Terri -- epoxy isn't the greatest for filling / sanding because it remains slightly flexible after curing. And it is quite toxic and messy.
guitarlute101
« Reply #7 on: August 29, 2014, 01:43:27 AM »
Thanks Terri and Bo!
