Author Topic: Bristol Scout C (1/72, MAC Distribution)  (Read 20800 times)
Re: Bristol Scout C (1/72, MAC Distribution)
« Reply #15 on: August 15, 2014, 09:14:51 AM »
Excellent job on making the mod's so far Prze . On the instrument panel , is the instruments clear film or is this decal . Looks pretty dame good !
« Reply #16 on: August 28, 2014, 06:17:09 AM »
Thanks for the kind comments, lady and gentlemen.
Terri, the instrument panel is from the clear film and the PE part included in the kit.
In the meantime Gnome Lambda arrived from Small Stuff (great customer service, as usual!). Assembling it was yet one more strain to my eyes, I had to resort to a magnifying glass (for the first time in my life!) but I managed to do it!!! Apart from my attempts to put it together, with every bit I added to it my admiration and awe to the manufacturer of this little gem grew on. So, here it is
And I also worked on the fuselage - added the tailplane, the firewall and the fuselage bottom at the exhaust zone. All the joints were filled, sanded and polished. I have sprayed a dark grey paint to check the quality of these works, you can still see it at some places.
Two funny spurious stich lines under the tailplane removed (it seems that guys at MAC took the tailplane struts at the side views as the stich lines!), as was the too deep imitation of the inspection panel. The panel will be reinstated using the kit PE fret.
The correctly located recessed lines along the stiching will serve me as a lead to attach the PE stich pattern from Part. The fuselage also got the wire pins to be used to reinforce the lower wings joints which are only by the wing spars leaving gaps between the wing and the fuselage. They will indeed require some extra strength.
Offline xmald
« Reply #17 on: August 28, 2014, 06:23:19 AM »
Przemek great job on the kit!!! Those resin engines look magnificent. It is rather hard to handle a spark plug in 48th scale, in 72nd it has to be a nightmare. Cockpit looks great, as well as your modifications on the kit.
Best regards
Filip
« Reply #18 on: August 28, 2014, 06:26:29 AM »
That engine looks most impressive. As usual you make difficult tasks look easy - the true mark of a master. This is going to be another masterpiece from your bench.
If you wear glasses (as I do) can I suggest a clip on lens with x10 magnification (as I have mentioned in previous posts) - it makes life so much easier with the small parts. They are not expensive and are worth every penny or cent.
« Reply #19 on: August 28, 2014, 08:16:01 AM »
Beautiful work on that engine! I have to use a magnifier for 1/32nd plugs and that is even too difficult  :-[
« Reply #20 on: August 28, 2014, 08:49:00 AM »
Beautiful work on the interior Przemol, the seat looks exceptional and the Small Stuff engine is simply amazing, this is shaping up to be a real stunner.
Offline Epeeman
« Reply #21 on: August 28, 2014, 06:36:46 PM »
Prez -
Will simply echo what others have already said regarding your interior work and engine.
Excellent!
« Reply #22 on: August 28, 2014, 11:15:40 PM »
That is one detail engine for 72 scale !
« Reply #23 on: September 03, 2014, 07:40:42 AM »
Thank you everybody!
LoneModeller, I do not wear glasses, yet. For a moment I think of a large magnifying glass with a base. But thank you for the hint. I am afraid the time comes wen I may really need it  ;)
And in the meantime I have basically prepared the bulk for painting. Attached the lower wings, drilled the holes for struts, rigging and control horns, preshaded the undersides with the lines of ribs and spars, added Part PE stiching, PE fuel tank caps and metal adhesive tape inspection covers. I could not find any spare PE step rims to dress the hopeless holes in the kit parts. But then the idea came to me to canibalise these from two spare old Airfix Pups fuselages. I managed to cut them carefully with the surroundings using a sharp razor blade, then trim them and delicately sand them.
Now for bare metal and linen colours!
« Reply #24 on: September 03, 2014, 07:44:53 AM »
Excellent Prze! I missed the motor update before -- that is stupendous.
« Reply #25 on: September 03, 2014, 09:17:46 AM »
Spectacular work as always, Prez!  Have you decided on a scheme, or did I miss that one?  Oh, yeah.  Hawker.  Sorry. :-[
« Last Edit: September 03, 2014, 09:43:13 AM by coyotemagic »
« Reply #26 on: September 03, 2014, 09:30:53 AM »
The stitching on the fuselage looks great and your wing shading also looks very good.
« Reply #27 on: September 03, 2014, 09:34:18 AM »
Did you use a sharpie pen for the frame work ? This is what really messed up build . The ink bleed through the future , lacquer and paint and now I have to start all over again  :(
Splendid work as always Prze ! Nice touch with the lacing on the fuselage side  :)
« Reply #28 on: September 03, 2014, 09:36:16 AM »
Awesome prep work for the see through ribs! You are always an inspiring builder!
« Reply #29 on: September 03, 2014, 11:32:19 AM »
Beautiful work as usual, Prez!
