Author Topic: Roden 1:32 Nieuport 28c1 95th Aero Sqn  (Read 29359 times)
Re: Roden 1:32 Nieuport 28c1 95th Aero Sqn
« Reply #15 on: July 08, 2014, 09:33:43 AM »
Many thanks for all the nice words of encouragement; if I "pooch" the assembly in the absence of WNW engineered struts and fittings there won't be a hole deep enough for me to hide in! :-[ On the other hand, this just might be the ultimate test of my cherished Aeroclub Bi-Plane Assembly Jig. Just about ready to start some paint spraying; I must admit that, as pretty as this Kit is, the clean up is something we all forget about when working with WNW products. In all fairness this Kit's been around a while, and the mold is probably getting a little "loose".
« Reply #16 on: July 08, 2014, 09:37:01 AM »
Well Lance this build is the final push I needed. Been looking at buying one for the past month and now its on order. Looking forward to following your build and getting pointers. The plastruct sheet, is that pre grooved or did you score it yourself?
James
    Great work James! Hope you got a decent price on it. The Sheet for the cockpit wood work is plain; I grooved it with a fairly worn #11 Blade.
 Have you decided on markings yet?
« Reply #17 on: July 08, 2014, 09:40:17 AM »
Ron & Richard,
   I am really looking forward to the seat, it looks excellent on the Site. If I read your comment correctly, Richard, I'll be very pleased to try the cowling, that's very kind of you!
Offline jknaus
« Reply #18 on: July 08, 2014, 10:41:55 AM »
James
Not too bad a price. And I also have Super Scale International MS320244 decals coming. 2nd Lt. Ralph O'Neill 147 Aero Sqn. Now to get a gun from Gaspatch, a seat and I guess a cowl from Aviattic, and whatever else I can copy from you lol. But first things first a Fokker, Rumpler and Snipe to finish. At least that gives time to aquire more refs and stuff :)
James
« Reply #19 on: July 08, 2014, 11:40:48 AM »
This is going to be a real treat following along on this one  :)
« Reply #20 on: July 08, 2014, 11:40:56 AM »
James,
   Nice scheme, it's the one of three available that I didn't get, and probably the most unique. I'd be very interested in what you can confirm on the type of Lewis Guns to mount on this beast; I was going to go with the Colt Version but ended up ordering the British Hyland with the Type E loading handle, seemed to look the closest to what photos I had.
« Reply #21 on: July 08, 2014, 02:15:36 PM »
Hi Lance - one of my favourite planes and one of the greatest stories of WW1 aviation .....your peach basket seat, an improved version of Ron Kootjes earlier version, is on its way along with a cowling which I'll be marketing soon - a vast improvement over the kit one...
This'll be worth watching for sure!
Regards, Richard
I assume Ron has corrected the fit issue I encountered with the original. I am glad to hear that this correctable, but somewhat frustrating issue has been resolved. I also like the idea of the cowling... I am so... tempted to get another and try to improve on mine. Lance you are going to have a blast with this kit as it really does build up nicely. I am sure whatever version of the Vickers you chose will be a better representation than the original kit  8)
« Last Edit: July 09, 2014, 05:50:13 AM by RAGIII »
« Reply #22 on: July 09, 2014, 05:44:56 AM »
Hi Lance:
This is one of Roden's better if not best kit.  I built it early on and really enjoyed it and did it in Roosevelts markings.  The stripes on the cowling can be a tad tricky to get even.  Great model.  Looking forward to seeing you work through the build.
« Reply #23 on: July 09, 2014, 06:16:40 AM »
Everyone seems to see this as a pretty good Kit, and I agree thus far. It's a very simple construction but, other then lack of detail on the smaller parts, a nice portrayal of the aircraft. I think it'll build up quite nicely, hopefully comparable to some of the excellent Builds you Folks have displayed here!
Offline stefanbuss
« Reply #24 on: July 09, 2014, 11:04:14 PM »
This one will be followed closely and I am already expecting a very instructive built-process. (Is this proper english? Nevermind)
Stefan
« Reply #25 on: July 10, 2014, 05:12:18 AM »
   Thanks Stefan, I'll try to keep it interesting! ;)
    Made a bit of progress despite the effects a minor disaster here; we had a pipe leak in the ceiling of our downstairs, water damage to the walls and flooring but thankfully minimal damage to the contents of the room. (Spare bedroom) All is in hand with the Insurance and repair people, now it's just the inconvenience of all the work being done over the next several weeks. I feel very fortunate that, at this stage , it appears that the damage is limited to just the one room!
   So, in my few spare moments I completed the engine. This aircraft had the 160HP Gnome Monosoupape 9N Rotary installed. The Kits engine is very "plain" in appearance and has a few errors that stand out. Although the engine is almost totally concealed by the cowling I elected to detail it a bit. First, a complete clean up of the parts was required, lots of flash and mold marks being removed. A second Spark Plug (Plain plastic sprue) had to be added to each cylinder to match the twin plugs of the original and different shades of Alclad II Metal Paint were used. Once assembled I added the electrical wires to the plugs to complete the job. After fiddling with first copper wire, then stainless guitar strings, I elected to use EZ Line for the wires which worked very well. A wash of very thin Model Master  Semi Gloss Black added some "grungy oil effect" with some shading effect as well and she was done.
  The only other thing I'd consider doing different in retrospect is replacing the lifter rods. they are a little thick even after considerable shaving while cleaning them up, For the tiny bit that is visible, however, I'm quite pleased with the results. Now it's on to module #2, the cockpit.
« Reply #26 on: July 10, 2014, 05:32:22 AM »
Hello Lance:
Engine looks pretty darned good Lance.   The paint work will certainly add some interest to the front end.  I like using EZ line for plug leads as well as it has the desired effect.  Bummer about your basement.  I have had simliar experiences here in the great upper midwest and it is quite unsettling.  Hope all turns out well for you and you can continue on with minimal disruptions.
Offline jknaus
« Reply #27 on: July 10, 2014, 11:31:14 AM »
Great start. Like the engine. Looking forward to the cockpit.
James
« Reply #28 on: July 10, 2014, 08:23:33 PM »
Your Engine looks terrific. Exceptional painting!
« Reply #29 on: July 11, 2014, 02:38:24 AM »
Excellent job on the engine, Lance. The sprue sparkplug and the easyline
worked a treat.  Good to hear that the leak damage is being looked after.  Never
rains but it pours, eh?  Looking forward to the next updates when you are
back at the bench. :D
