Author Topic: Roden 1:32 Nieuport 28c1 95th Aero Sqn  (Read 29599 times)
Re: Roden 1:32 Nieuport 28c1 95th Aero Sqn
« Reply #30 on: July 11, 2014, 02:49:41 AM »
Brilliant work on the engine, Lance!  Really looking forward to following along.
Offline stefanbuss
« Reply #31 on: July 11, 2014, 02:50:34 AM »
Happy to hear about your desaster recovery. Very convincing work on the engine.
I am eagerly waiting for your works on the cockpit.
Stefan
« Reply #32 on: July 11, 2014, 04:32:23 AM »
Hi Lance.
I really like the innovative use of EZ line on the engine - and I'm glad to hear that the leak and water damage are being sorted.
« Reply #33 on: July 11, 2014, 04:53:10 AM »
Thanks for all the comments; not getting much done right now with all the comings and goings of the "Demolition and Cleanup" crew.  :( Very disruptive to the routine here and the repairs/rebuild have yet to start. I'm hoping to get the cockpit module together and then install the seat once it turns up in the mail. I'll keep posting mini updates.
Cheers, ::)
« Reply #34 on: July 11, 2014, 05:15:51 AM »
If you put fuel into that engine will it start up? It looks as though it would!!
Sorry to hear about the leak - water is wonderful stuff but it has to be in the right place! Hope all gets sorted out sooner rather than later and that you can maintain your sanity while the repairs are carried out.
« Reply #35 on: July 11, 2014, 06:10:29 AM »
   Thanks for the well wishes LM. As much as it's a large pain in the posterior this could have been a lot worse, we were very lucky to discover it before more of the downstairs was destroyed, and the impact on "contents" was minimal. As for this Nieuport, I'll just continue to work along as the chaos allows! :P ::)
Offline xmald
« Reply #36 on: July 11, 2014, 06:13:11 AM »
Looking good Lance as always - your simulation of planking???(don`t know how to call it properly) inside the fuselage is something to follow!
Best regards
Filip
« Reply #37 on: August 02, 2014, 12:22:22 AM »
   Real time progress, though very slow, has got well ahead of this Build Log. Time for an update .............
   Since no locating pins are molded into the fuselage I added a little extra by way of rough brackets to aid with alignment and strengthen the final assembly.
   The ailerons have been removed from the lower wing and steel pins installed.
    The Aviattic (Ron Kootje) "peach basket" seat well worth waiting for as supplied and ready to install. Not seen, the cushion supplied with it, I'll catch that with a shot or two of the seat with the belts installed.
Before.........
and after...............
 Once assured that the cockpit module would fit (I ultimately had to remove a portion of the aft circular frame to allow it to slide into the closed fuselage) the fuselage was closed, filled, lower wing installed,
and then sanded down to a "ready for paint" state.
 The lower wing attachment was a little "rough" but easily remedied with several applications of putty, in this case Squadron "Green Stuff" filler.
 I've since completed the pre shading, this had to be done in two sessions as I forgot the small "half ribs" on the lower leading edge of the bottom wing (?!?!) first attempt. The ailerons were done as well, the tailplane, being veneer covered was left as is. I'm hoping to get away with pre-shading only on this one as the references I have show generally clean looking machines and not a lot of rib detail on the wings.
 The lower wing joints filled and finished.
The upper fuselage....
  and some of the completed pre-shading.
   The Aviattic sample cowling was cleaned up to a finished state and, at this point, will be the one of choice as it has the rivet line molded to the front portion, something missing on the Kit version as can be seen here.
  The seat has been completed with bits and pieces of HGW Seat Belts from the spares box and I'll include a few closeups in the next update. Almost time to start mixing some of those off the wall French Cam. Colours! ;)
« Last Edit: August 02, 2014, 09:02:00 AM by Des »
« Reply #38 on: August 02, 2014, 05:59:22 AM »
Outstanding update, Lance!  She's coming along beautifully.  The cockpit and shading look fantastic.
Offline petrov27
« Reply #39 on: August 02, 2014, 07:25:44 AM »
Looking really great - do you just use a thinned black for the preshade?
Also - Aviattic Cowling? Didnt know they did one for the N28?
-Patrick
Offline Vickers
« Reply #40 on: August 02, 2014, 07:33:18 AM »
Your N.28 looks really fantastic, Lance.  The warmth of the interior wood grain appears to be consistent with the tones used in French aircraft, nice work on the interior skin.  I have this one in my stash as well, so I'm glad I haven't built it yet. I already see several things in your build that I wouldn't have thought of which I may attempt to emulate when the time comes. Keep up the good work!
Offline oldalbie
« Reply #41 on: August 02, 2014, 08:44:12 AM »
Looking really nice.  I have the 1/48th almost done.  The locating pins for the struts are a major PITA though.
Offline jknaus
« Reply #42 on: August 02, 2014, 08:55:08 AM »
Looking really good Lance. Cant wait till I can start mine after seeing this.
James
« Reply #43 on: August 02, 2014, 08:58:36 AM »
Great update Lance, she is look excellent, good idea with the tabs to assist with fuselage halves aligning correctly.
« Reply #44 on: August 02, 2014, 09:16:42 AM »
Your motoring right long with this one Lance . I like the warn honey shade on the seat , will contrast very nicely with the surrounding frame work !
