Author Topic: aaaaarg!  (Read 2173 times)
Offline nmroberto
aaaaarg!
« on: June 29, 2014, 03:38:48 AM »
CRAP.
Just about finished my 48th scale Eduard Pfalz D. IIIa when it got knocked off the work bench breaking the landing gear.  Now I can't find the strut pieces in the carpet monster.
Tried cutting some new ones out of styrene sheet but they looked horrible.
I guess I could say that the Pfalz was a top secret experimental model with retractable landing gear.
Robert
Offline kornbeef
Re: aaaaarg!
« Reply #1 on: June 29, 2014, 04:27:46 AM »
 :-\ Ouch!
Sympathies. You'll have to offer sacrifice to the carpet monster and it may give up your missing parts in reaction?
Keith
Re: aaaaarg!
« Reply #2 on: June 29, 2014, 10:08:08 AM »
Check out my latest post in the Hall of Shame Category.
http://forum.ww1aircraftmodels.com/index.php?topic=3669.0
 I will NEVER FINISH that Pzalz. So if no other solution arrises I would be more than happy to ship you the whole thing and you can use brake fluid or whatever to separate the gear. Send me a PM if you need the kit.
« Last Edit: June 29, 2014, 10:20:14 AM by RAGIII »
Re: aaaaarg!
« Reply #3 on: June 29, 2014, 04:03:12 PM »
i use plastruct butyryl coated wire for replaceing most kit landing gear as well as tail skids in 1/48. it is a soft/mild steel core with plastic coating. i  just bend it to shape then sand the aerodynamic shape to the strut shape. i use wire strippers to remove about 1/8" of plastic and glue the exposed steel wire into drilled holes. i got sick of breaking landing gear and tail skids.
http://www.dccsupplies.com/shop/product_info.php?products_id=1733
