Author Topic: Flashbacks W-29  (Read 3378 times)
Flashbacks W-29
« on: June 27, 2014, 12:43:52 PM »
This was one of those builds which fought back a bit with fit issue and a few corrections made . Under side of the fuselage was skinned with 20 thou card tapering out at the rudder . 2mm had to be sanding and carved away where the tail plane meets the fuselage for a good fit . the covers in this area I made out of 5 thou card which turned out rather well , but not perfect . The gunners pit was flared in with putty sanded and re-peated . The rad fit to the cowl also need mods done with the under side skinned and shims were added . I didn't add much detail to the cock pit other the control lines . Only the top side of the engine was detailed with valve springs , piping and spark plugs and leads . The wings had major sanding down to get them to scale thickiness and even then I could have sanded a bit more but I was getting tired of this . I ended up making all new struts , kit ones are to short . Makings are from the kit .
Re: Flashbacks W-29
« Reply #1 on: June 27, 2014, 12:44:24 PM »
Re: Flashbacks W-29
« Reply #2 on: June 27, 2014, 12:44:53 PM »
Re: Flashbacks W-29
« Reply #3 on: June 27, 2014, 12:45:25 PM »
Re: Flashbacks W-29
« Reply #4 on: June 27, 2014, 12:46:17 PM »
Re: Flashbacks W-29
« Reply #5 on: June 27, 2014, 07:41:10 PM »
Sounds like you had a bit of a battle with this one, Terri, but you
succeeded with a great model.  Well done!
Re: Flashbacks W-29
« Reply #6 on: June 28, 2014, 01:43:30 AM »
Another one of you beautiful builds, T!  I love all the work you did accurizing a pretty rough kit.
Re: Flashbacks W-29
« Reply #7 on: June 28, 2014, 02:01:54 AM »
I think Bud and Ernie hit the nail on the head with their positive comments, Terri. Well done! This must have been one of those models which aged you years in the process of completion. My ham-fisted efforts at a Roden SE5a seemed to turn my hair white overnight.
Re: Flashbacks W-29
« Reply #8 on: June 28, 2014, 02:22:24 AM »
I wholly agree with the comments above - you have turned a sow's ear into a silk purse and demonstrated real modelling skills in the process. Excellent model and finish. More please.
Offline Epeeman
Re: Flashbacks W-29
« Reply #9 on: June 28, 2014, 03:52:08 AM »
Well done, Terri - looks terrific.
I bet you ended up with stronger arms once you finished sanding those wings ............... ;D
Re: Flashbacks W-29
« Reply #10 on: June 28, 2014, 07:02:01 AM »
Terri,
   First time I've seen this one, and She's a beauty! Often taming a bad Kit is more satisfying then a perfectly done decent Kit. You certainly conquered this one.......nice work!
Re: Flashbacks W-29
« Reply #11 on: June 28, 2014, 10:05:59 AM »
Yeah there was a bit of fight with this one but I figured if I kept using colourful language it would follow suit and cave in . Even if I did gain a few gray hairs in the process  :-X
Thanks guy's for the positive comments  ;D
Re: Flashbacks W-29
« Reply #12 on: June 28, 2014, 08:38:33 PM »
Dittos to my Amigo. Really well done Terri!
Re: Flashbacks W-29
« Reply #13 on: June 29, 2014, 02:52:09 AM »
Thanks Rick  ;D
Re: Flashbacks W-29
« Reply #14 on: June 30, 2014, 03:33:28 AM »
Dittos , you now have the trifecta from the 3 Amigos.
