Author Topic: Decal problem  (Read 2322 times)
Offline nmroberto
Decal problem
« on: June 24, 2014, 09:17:50 AM »
I'm building a Eduard Fokker D VII and using the Eduard decals.  They are thin, and go on easy but when dry are extremely fragile.  All you have to do is look at them and they chip or scratch.
Anybody got any solutions?
Robert
Re: Decal problem
« Reply #1 on: June 24, 2014, 10:33:37 AM »
As soon as my decals are dry I spray them with a couple of coats of clear, this protects the decals, you can use either matt, satin or gloss clear.
Offline nmroberto
Re: Decal problem
« Reply #2 on: June 24, 2014, 10:45:50 AM »
I'll do that, thanks. Could I use something like Future?   How long do you let the decals dry, is overnight long enough?
Robert
Re: Decal problem
« Reply #3 on: June 24, 2014, 11:10:37 AM »
I'm not a fan of Future but a lot of our members swear by it. My main clear that I use is Humbrol Clear Cote, the one in the glass bottle. After I apply my decals I hit them with some heat from a hair dryer, then I usually leave them for about two hours before spraying the clear, a lot of peole do leave the decals overnight to thoroughly dry.
Offline nmroberto
Re: Decal problem
« Reply #4 on: June 25, 2014, 07:54:32 AM »
Thanks for the tips Des.
Although I'm getting pretty good at mixing paint colors to match decal colors.  :D
Robert
Offline ww1buff
Re: Decal problem
« Reply #5 on: July 01, 2014, 08:08:45 AM »
One trick I use, although it might be risky with a brittle lozenge decal, is to coat the surface with Future just before laying down the decal.  You have to work quickly and be very careful with placement since the Future starts to dry immediately.  The decal can be moved before the future dries if necessary by slipping some water under a corner and working it around.  As the decal dries, brush the bubbles to the edges.  The Future will flatten out as it dries and that decal isn't going anywhere.  Coat the decal surface with Future to seal it.
This has worked really well for me, but as I said, it might be risky with a large, brittle decal.
Joe
