Author Topic: A request to the am manufacturers  (Read 3210 times)
Offline jknaus
« on: June 19, 2014, 10:03:02 AM »
Okay I dont know where to put this so I hope this is a good place. I cant quite drill a hole in the WNW kits control horns. Those pieces that the cable attaches to on the elevator, rudder and ailerons. So I had an idea. Maybe I could make a cable connector. Well thats too small for me to scratch as well. Then I thought, hey there are people here who work on miniscule pieces. I've also seen some of my favorite am guys here also. So here is my request. Could one or more of you consider making a cable connector in resin or metal that I can slip on the control horn and also glue ez line or something like it into the other end. Then I can rig my controls. It would look like this.
I'm sure a lot of other guys here would buy into it as well.
I hope this request is in the right place and is okay Des.
James
Re: A request to the am manufacturers
« Reply #1 on: June 19, 2014, 10:21:50 AM »
No problems at all James, it is great to see requests for new products, and this is a particular item that I'm sure will be extremely popular with all our members, I hope there is someone out there who can manufacture this item. A clevis like this has many uses not only to connect cables to control horns but hooking up cables to the engine and the throttle quadrant.
« Last Edit: June 19, 2014, 01:52:07 PM by Des »
Offline Mark
« Reply #2 on: June 19, 2014, 11:42:49 AM »
Yeah, I'm at the point of rigging the various control horns on my D.VII F and I'm still not sure how I'm going to attach the line to the horns except wrapping it around and applying a drop of CA. Any suggestions?
Mark G.
« Reply #3 on: June 19, 2014, 12:32:59 PM »
Hi James.  I think the idea of the connector is a good one and I think at some point
someone will produce it.  Until then, I think the control horns can be drilled to
accept the easy-line, or monofilament, etc.  I've done it with 0.3mm drills without
any problems and it will hold together if you don't put too much stress on it.
Food for thought. :D
Offline jknaus
« Reply #4 on: June 19, 2014, 01:08:25 PM »
Thanks Ernie. I have tried on one of my other builds, but I ended up wrecking more than I did successfully drilling out. After that I just glued the ez line onto the horn. It works, but doesnt look the best. Then I thought of the real deal and tried to make a cable connector. That didnt work. I'm fairly sure though that if I had one I could do the job.
James
Offline Mossie
Gerry "Mossie" Mos
Mossie3DCAD
"Prompt & Precise"
https://www.facebook.com/gerry.mos.9
« Reply #6 on: June 19, 2014, 04:18:26 PM »
Hello all.
Ernie has shown us to splendid effect recently just what can be achieved by careful drilling, though I fear that I might not have  such skill and think that James is really on to something here.
« Reply #7 on: June 19, 2014, 08:07:25 PM »
Nigel, you're too kind. :-[ ;D  I think James original idea would be splendid and a really
well received item for one of our after-market friends to produce.
« Reply #8 on: June 19, 2014, 09:59:05 PM »
Until some enterprising soul does bring such a clevis onto the market, I've found that an Optivisor combined with the sharp carbide bits from Drill Bits Unlimited made all the difference for me when drilling those delicate spots.
« Reply #9 on: June 20, 2014, 01:23:04 AM »
« Reply #10 on: June 26, 2014, 01:34:20 PM »
also you can replace the plastic kit control horns with a photetched control horn which has the holes already there. eduard and part make them.
http://www.scalehobbyist.com/manufacturers/Eduard/Objects/wire-stretchers-turnbuckles-and-control-horns/EDU00048406/product.php
Offline Ian from Doncaster
« Reply #11 on: June 26, 2014, 08:06:03 PM »
Without rooting through my stash and old WNW instructions, are not some of the control horns pre-drilled?  I thought some are, and some are not.
Drilling through is OK, but can be tricky - one slip and the part is damaged, however repairs are possible.
