Author Topic: Pfalz D.IIIa 1/48 scale  (Read 5551 times)
Re: Pfalz D.IIIa 1/48 scale
« Reply #15 on: June 20, 2014, 10:11:25 PM »
Thanks everyone for the kind comments  :)
Bud , you got it . Will get some pic's post of the strutter float plane after work today .
Offline vincentm
« Reply #16 on: August 19, 2014, 08:56:50 PM »
I'm getting crazy about the Pfalz D-III. I'm currently completing the 3 Fw190 models I started as a 'relax time' after my Albatros, and then it'll be time to build a Pfalz D-III. I just can't make up my mind about the color scheme. Believe it or not, I just dreamt of it last night...Since I definitely cannot chose between the aircraft of Hans-Georg von der Marwitz (overal silvergray with orange geometric markings) and this very one...I think I'll make both!
Offline vincentm
« Reply #17 on: August 22, 2014, 09:54:00 AM »
PS: I have one question. How did you chose the color of the rib tapes? d'you have any information about rib tape color on Pfalz fighters?
« Reply #18 on: August 22, 2014, 09:40:34 PM »
Hi Vincent ,
For the rib tapes it is going to be either blue for the top , pink for underside or lozenge . Depends on which scheme you chose do to . At the Pfalz Factory there wasn't a set rule and they used what on hand at that time . I'll dig through my refs this weekend for you .
Offline Vickers
« Reply #19 on: August 23, 2014, 02:13:35 AM »
The blue you used on your Pfalz D.IIIa is just beautiful, Terri. Getting a brightly-colored paint to look natural on a WW1 aircraft often requires more planning and care than meets the eye. Marvelous job all around!
« Reply #20 on: August 23, 2014, 04:29:06 AM »
Another excellent model. Your finishes are something to be really proud of - just wish I could get that effect every time. Keep posting more - they really are very good.
« Reply #21 on: August 23, 2014, 05:10:01 AM »
Hello Terri:
Great job on the lozenge, preshading and the weathering around the radiator, of course, the rest of the model looks wonderful as well.
Thanks for posting.
Offline vincentm
« Reply #22 on: August 23, 2014, 11:02:15 AM »
OK thanks by advance for your searches on the rib tapes, Terri.
Quote
I totally agree, especially when you're planning to build the same bird and would like to get  the same well balanced color. So what kind of paint did you use?
« Reply #23 on: August 24, 2014, 09:27:19 AM »
Thanks guy's  ;D
The paints I use are Tamiya , for this build Tamiya X4 plus their brand of thinner and sealed using Testors dull coat in their glass jars thinned and shot through the airbrush . This was sprayed using a Paasche Eagle Talon airbrush . I love this airbrush for the fact that it has great atomization of the paint . Key to this is using lacquer thinner . It breaks down the paint particles better than any other thinner and it's properties are close to water . ( finer the mist , smoother the finish will be ) .
« Reply #24 on: August 25, 2014, 01:37:00 AM »
Nice Pfalz Terri!
The paints I use are Tamiya , for this build Tamiya X4 plus their brand of thinner . . . Key to this is using lacquer thinner . . .
Just for clarification Terri, you're using Tamiya's proprietary lacquer thinner here? I've been using Home Hardware's lacquer thinner (dirt cheap for a litre) with good results too, but just for fun, maybe I should give the Tamiya brand a trial run.
« Reply #25 on: August 25, 2014, 05:11:21 AM »
Hi Chris ,
Yes Tamiya 's brand of Lacquer thinner . I used to use what ever brand the hardware store had/paint store and found that the paints don't stayed mixed for very long causing a few troubles while spraying . I still use the hardware store brand for thinning Humbrol and Testors Model Master paints . Never had an issue with separation . I also use their regular thinner as well X20a .
Give the Tamiya Lacquer thinner a try Chris , one will last me a long time . I don't use it for cleaning the airbrush , store brand works a charm .
« Reply #26 on: August 26, 2014, 09:34:07 PM »
What else can one expect from Pfalz Girl?  ;) Lovely, blue, a Pfalz. One can ask for no more!
Offline vincentm
« Reply #27 on: August 27, 2014, 04:17:34 AM »
Thanks for the explanations Terri. OK for Tam X4. I wouldn't have guessed since the color looks darker in the bottle. I think it took this nice greyish look after you've sprayed the matt varnish.
