Author Topic: WNW D.Va with a side order of AMS  (Read 19463 times)
Offline kornbeef
Re: WNW D.Va with a side order of AMS
« Reply #15 on: June 10, 2012, 02:25:59 AM »
Chris, Hi and thanks.
Basically I cut the base from the back of the seat, building up the cushion on the base of the seat with Milliput, sculpting it while still setting to form the dimples creases and seams then sanded tweaked and polished it when dry, For the buttons I drilled through the base, tidied up around the button places and slipped plastic rod into each hole to a level that looked right. Once happy I glued them with liquid poly and snipped off the ends that protruded underneath.
I hope this helps, anyone wanting to do this, you can of course make a seperate cushion pad by using a thin base of plasticard ubder the milliput but I wanted to model the seams and cushioning around the back and sides too.
Hope this explains things okay.
K
« Reply #16 on: June 10, 2012, 03:45:46 AM »
Really glad to see you back on this one, Keith.  Brilliant detail work all around.  Who says you can't improve on a WNW kit?  That seat cushion is superb.
Offline phs Paddy
« Reply #17 on: June 10, 2012, 11:02:19 PM »
Great attention to detail. You just have to give us a rundown on how you did your seat cushion. It looks superb!
I second that. That cushion really is well done.
Paddy
« Reply #18 on: June 10, 2012, 11:20:38 PM »
Keith,
   As mentioned earlier, brilliant work. I'll be following closely and will keep your cushion technique in mind for my DVa build in future. You are setting a record level of performance for rampant AMS, well done!
Lance ;)
« Reply #19 on: June 11, 2012, 01:07:00 AM »
 Keith,
First off more outstanding progress my old friend. I'd like to take this opportunity to thank you for this highly informative thread. Your many modifications and additional details are out of this world. You've done a great service to anyone interested in building their own D.Va, major cudo's to you for that.
Offline kornbeef
« Reply #20 on: June 11, 2012, 01:22:49 AM »
Gregory, my ethos...oooh posh word. Is that info is for sharing, I'm not one to watch someone else make mistakes I could advise against. I imagine most if not all here are of the same as myself. But thank you anyway my friend.
For the greater good of all ::)
Keith
« Reply #21 on: June 11, 2012, 07:57:08 AM »
Beautiful work, I remain in awe.
Offline kornbeef
« Reply #22 on: June 18, 2012, 03:41:14 AM »
Thank you Tony.
So next installment time.
Engine.
Now the basic assembly and painting is underway.  I just had to use the Barracuda Inlet manifold in its completion, that extra detail is just too good to resist. I haven’t found a decent pic of the chosen profile’s engine to say yay or nay so I’m running with this. Still a long way to go with paint and detail, I’ve assembled it in two parts. The cylinders manifold and maneto tower and the vlock on its own. This helps with detailing. I hope. The block can be fitted when the fuselage is assembled. As I said theres still a lot of detail and paint to add, looking at high rez pics I think it needs it.. lol
Tanks.
Same as the engine, Basic assembly, base paint, some detailing done, I tried to replicate the solder seams with some success, the cartridge chutes are added making sure everything fits in the fuselage (it does upto now)
Ammo cans
I’ve started hese, modding the cartridge belt holder is the biggest mod, I opened up the ammo feeds to the guns, PE flaps will be added, small extra details to be added.
Radiator.
Now a fairly big mod... could have turned out much worse, von Sleich’s craft appears to have a rad with a single reinforcing bar so I carefully shaved an d sanded the two on the WNW rad off and added one. Also it has a slide type shutter beneath I tried to replicate, with no real evidence of the arrangement I wasn’t happy and am in the process of redoing it.
Zoerst.
Added the flanges from the spare Cylinder half, a tiny detail but AMS demanded it!
Fuel control panel.
Something close to finished. Added the valve assemblies from bits from the spares box, the levers are modded Bronco single wing butterfly nuts.
Seat.
Done apart from final weathering and such. I used lead for the belts, fitted to Eduard buckles attachments and clasps. At pic time I noticed the blocked holes on the clasp.. sighs.  I think I got the leather effect I was looking for this time.
Well thats all for now guys n girls.   Comments as always more than welcome, no matter if good bad or pointers.
Cheers Keith
Seems I have a photoshop issue...lol will correct posts laters. dun hopefully. :-\
« Last Edit: June 18, 2012, 03:54:01 AM by kornbeef »
« Reply #23 on: June 18, 2012, 06:34:02 AM »
  Keith,
Amazing details my old friend. Each detail in today's update in itself is outstanding,but the seat is something special. You've got the leather look spot on perfect to my eyes. Please do tell me how you managed to get such perfect results.
Offline kornbeef
« Reply #24 on: June 18, 2012, 07:44:50 AM »
  Keith,
No... it's a trade secret Gregory!
Seriously. quite simple (building aside) using Citadel paints  I basecoated in chaos black rattle can (having a son who is into warhammer has its perks) Over that I brushed roughly (sort of drybrushed but more blotchy) a dark redbrown (Lifecolor Rotbraun (yes WWII German armour camo) and dry brushed Citadel Tallarn lesh over that to pick out details. After sealing it all in with Future and letting it dry for days, a final double coat of Citadel Fleshwash gave it that rich patina allowing the colours beneath to glow through.  I normally use the same washe but a lighter base, I'm more pleased with this though.
TY for the great comments too..  ;)  Keith
« Reply #25 on: June 18, 2012, 07:50:06 AM »
Amazing work on this one. Love the deep colours on the seat!!!
« Reply #26 on: June 18, 2012, 08:46:15 AM »
    Keith,
Thanks very much for revealing such well guarded  trade secrets my old friend. I'll have to check at the LHS next visit to see what Citadel paints are in stock. To date I've only used Citadel Bleached Bones for the interior CDL for my N.28. Nice paint too for brush painting,not tried it yet with the airbrush though.
« Reply #27 on: June 18, 2012, 08:49:55 AM »
Beautiful work... Rad mod is seamless ... Amazing
Offline kornbeef
« Reply #28 on: June 18, 2012, 08:51:26 AM »
My pleasure Gregory, Senseless keeping such things to yourself, if I can I hope my blog brings idea's to others, I learn more in turn from what others show, sometimes the most simple things... just  share nd share alike. Knowledge isnt power, its a tool to share with one another.
BTW  I thin Citadel with Tamiya X20-a thinners  gives nice results, I use Citadel quite extensively.
Keith
Offline Fokker boy
« Reply #29 on: June 18, 2012, 09:57:33 AM »
This is looking great.
Kevin
