Author Topic: Bending brass tubes  (Read 2429 times)
Offline stefanbuss
Bending brass tubes
« on: May 30, 2014, 06:09:00 PM »
Friends,
I know how this works in real life for hydraulic lines - unfortunately I don't have a bending machine available (apart from the fact that this machine would be slightly overscale...).
How can I bend a brass tube with an outer diameter of 0.8mm, without just folding it? I want to replicate the long cooling pipe running towards the radiator, on an Albatros DV.
Any ideas?
Stefan
Offline stefanbuss
Re: Bending brass tubes
« Reply #1 on: May 30, 2014, 07:23:52 PM »
I need a tube, as I want to show the open/disconnected end of the coolant pipe. A solid rod unfortunately is no option.
« Reply #2 on: May 30, 2014, 08:11:41 PM »
No problem.
First heat it to remove the temper
You don't need a bending machine. Just make a jig from drill bits and a piece of scrap (anything). A picture here is worth a thousand words, excuse me while I go draw something for you....
« Reply #3 on: May 31, 2014, 02:25:29 AM »
let me know if this requires further explanation...
p.s. I will be making the same parts for my alby very soon, so stay tuned :)
« Last Edit: May 31, 2014, 04:19:12 AM by Bo Monroe »
« Reply #4 on: May 31, 2014, 02:43:13 AM »
I've had a great deal of success placing a light gauge high E guitar string into the tubing, bending it, then removing the guitar string.
« Reply #5 on: June 08, 2014, 02:36:34 PM »
i was about to post the same solution as coyotemagic. this is an old trick to put wire inside a piece of tube so it does crush when bending. i would do that even if you build a jig like bo drew.
Offline stefanbuss
« Reply #6 on: June 11, 2014, 03:38:29 PM »
Quote
Sorry for my lack of understanding - isn't the idea that the wire prevents the tube from being crushed? Am I missing something obvious (or obvious for a native English speaking person)?
Stefan :o
« Reply #7 on: June 11, 2014, 06:11:22 PM »
I think that's a typo Stefan ;) Scott meant "doesn't"
Offline jknaus
« Reply #8 on: June 11, 2014, 08:18:09 PM »
Another option would be solder. Easy to bend and soft so you can drill out the end. I've used that on armour before.
James
