Author Topic: How to avoid 'tenting' decals?  (Read 3301 times)
Offline OEFFAG 153
  • Just another Wingnutter
    • Terfors Creative
« on: May 30, 2014, 01:14:08 AM »
I have a problem that seems to repeat itself to some extent every time I apply WNWs/Cartograph decals.
Now, in all fairness – decaling may not be one of my modeling strong points, but I have read a few posts here on the forum that seem to have similar problems with WNWs decals. This thread is not meant as a bashing, but rather to find if I'm doing anything wrong and what I could do to improve.
I prep everything pretty well I think. Gloss paint, some buffing on the application surface, a couple of coats of future. Then a small amount of Micro set, and I slide the decal in place, using tepid water. So far so good. I then do my best to go over them using tissue paper, cotton buds etc to get them to settle over the shapes. Sometimes a small amount of Micro Sol is used. Not too much, as it seems to 'fry' the decals.
Once they are bedding down I always get 'tenting'. Over rib-tapes, rivets and edges. A bit more of Micro set and some elbow grease can improve the situation – but on some occasions it has gotten to the point where they simply lift and flake off after all is dry.
The Cartograph decals are very tough in my opinion, which I guess is good when I handle them. But are they perhaps a bit on the thick side – or is there something I don't do properly?
So any input, experiences, solutions to my problem of 'tenting' would be most welcome. Is there perhaps a product you swear by, that solves this annoying problem?
Many Thanks
Mikael
Building the WnW Hansa W.12 and Junkers D.1.
Offline kornbeef
Re: How to avoid 'tenting' decals?
« Reply #1 on: May 30, 2014, 02:19:39 AM »
Mikael
Use warm water to lift the decal off the carrier. Prick around the tented areas and use reasonably hot water on some lint free kitchen cloth to press them over details when applying once they are set in place and all other fiddling and air bubble removing is done. You can repeat this when decals are set in place too. but I apply a little Klear once pricked then press the hot wet cloth down hard as you dare/ are able.
Works for me.  Most times. I know some use hair dryers.
Keith
« Reply #2 on: May 30, 2014, 02:20:00 AM »
I just slather them with micro sol AND then absolutely do not touch them!!! They will bubble up and look weird when the stuff is wet, but then they will snug right down.
Offline rowan broadbent
« Reply #3 on: May 30, 2014, 03:50:48 AM »
Mikael,
Try the hairdrier on medium heat but still as hot as your hand can stand for a few seconds, then smooth down with a lint-free cloth.
Let's just stop to think about the physical/chemical processes involved in getting decals to sit down over detail or around tight curves/over edges (rudder decals etc). Firstly, consider the decal's manufacturing/printing process. This can be, generally, one of two types (dependent on the printing process used in their creation), either laser printed (such as Aviattic or Wingnut Wings "lozenge" decals) or screen printed as in Pheon or (most) WNW marking decals (some of their more elaborately shaded and blended designs are laser printed, even though they appear on the same sheet as the "conventional" screen-printed decals.. a neat trick by Cartograph!).
The method of production denotes the fabric of the decal itself:
Laser printed decals are printed onto decal paper which already has a carrier film or varnish coating over its entire surface and it is this coating which forms the body of the decal, with the design laser-printed onto its surface.
Screen printed decals are successive print layers of different colours laid down as thin layers of acrylic ink onto the decal paper's surface, or on top of a previous ink layer, with the final layer forming the transparent carrier film or varnish. Screen printing is a time consuming process, as each individual layer has to be completely dry before the next is applied - in the case of some of our more colourful decal sets, as many as twelve different layers are printed, each one a separate process where the "register" or "overlap" has to be controlled with enormous care ( we regularly ask Fantasy Printshop to deliver register accuracy of 0.075mm!).
Next, consider the actions of the various potions sold to allow or, more correctly, to force decals to conform. These potions divide into two distinct types: the "wetting agent" (as in Micro Set - the blue bottle) which serves to break the surface tension of the water in which the decal is floated onto the model and is composed of a relatively benign chemical - exactly the same effect can be obtained (much more cheaply) by a few drops of dishwashing liquid dropped into the decal water. The second type of magic potion is a very different chemical agent, often acetic acid (smell Micro Sol!) with other variations of varying concentrations/strengths. These agents chemically dissolve the screen-printed ink and as they evaporate and the decal dries out they should (note SHOULD), deposit the ink back on the surface, hopefully in the same order in which the different inks were printed. Sometimes (very often with the stronger brands) the thin ink layers of quality decals (such as those made by Cartograph and Fantasy Printshop) get mixed and scrambled by the dissolving process, leaving you with a complete mess. I admit to being unsure if these liquids have the same effect on the varnish layer of laser printed decals but suspect that they might.
NOW (I hope you're still with me, because this is the important bit), the application of heat to both types of decal also softens the decal itself, and thus allows it to conform to the underlying surface but, crucially, without risking the possibility of damage inherent in the dissolving process. A possible problem with too much heat is that the decal dries out and the glue layer then will not adhere to the model - a deft swipe of a small paintbrush lightly loaded with a water-soluble varnish ("Future"/Kleer work very well also) is often useful if applied as an additional/replacement adhesive beneath the decal, straight after the heat is removed, allowing the still soft decal to be smoothed down over the surface and adhere tightly - this method also ensures that there is no silvering visible on ANY of your decals.
The heat method has its own dangers; too much can fatally damage the decal by melting it into a crumpled mess and of course the underlying paintwork and even the plastic of the kit itself can melt with too much heat - but honestly, if you keep your own hand/fingers in the "line of fire" from the hair-drier, you'll remove the heat long before your decal (or the kit) is anywhere near getting damaged.
I've banged on about this subject at similar boring length before and a number of my customers have told me that they have used the chemical agents with total success, so the choice is yours. It does, like any worthwhile modelling technique, take a bit of practice,  but for me the hair-drier method is one I use every time and I still don't recommend the use of expensive potions magiques, reserve them only for Asterix et Obelix!
Rowan
(Pheon Decals)
Forget your perfect offering
Leonard Cohen
Offline drdave
« Reply #4 on: May 30, 2014, 09:13:33 AM »
Don't listen to him. He only makes them. Microsol is your friend. If it fails, buff it with a qtip and then a hair dryer. Buff it and microsol it. Never fails.  :D
Offline OEFFAG 153
    • Terfors Creative
« Reply #5 on: May 30, 2014, 08:10:41 PM »
Hi and Thank You guys – this forum is a fountain of knowledge.
I now have several 'new' tricks to try out next time I decal. I will perhaps do a test on an old model with some left over decals to see how they react to heat contra Micro Sol... That will be a fun exercise! :D
K.B., Bo, Rowan, Dave and Red Baron – Thank You again for your input!
Mikael
Offline WillScarlet
« Reply #6 on: May 31, 2014, 06:05:38 AM »
      To me, "lint-free rag" is an oxymoron.  :-\   I've never found one, especially in cotton. I HAVE found a great substitute however. Kimwipes (Kemtech brand) by Kimberly-Clark, delicate tasks wipers. 280 (11x21 cm) in a box  and not expensive. I use them exclusively in decaling to pat down and rub-out. Use for cleaning glass lenses also. Just a suggestion.
                               Will
« Reply #7 on: May 31, 2014, 11:17:44 AM »
Your high tech synthetic has nothing on my old T shirt!  ;D
No, seriously, some synthetic cloths are amazing, but well washed T shirts, the kind your Wife keeps trying to throw away, make excellent decal rags.
AGREES 150%
Offline Ronkootje
« Reply #8 on: July 03, 2014, 04:50:57 PM »
I use X20a from tamiya which is cheaper and works better then sol and set. spray it on with an airbrush/Brush also use they hair dryer witch works great as well
X20A has as a bonus its softens your paint witch will dry again and adhere to the decal very well.
Used it on my GV Gotha Bomber with home made decals.
Ron
Offline petrov27
« Reply #9 on: December 09, 2014, 05:18:40 AM »
X20A - isnt that Tamiya thinner?
-Patrick
