Author Topic: Re: Squiffy's Kites: RAF F.E2b night bomber,58 Squadron. 1/72 scale  (Read 61304 times)
Offline Squiffy
Re: Squiffy's Kites: 1/72 Bristol Scout
« Reply #180 on: April 27, 2015, 05:39:07 AM »
Thanks, chaps!
Very impressive collection, Squiffy, I admire your speed. ;)
Btw. on the first photo of the Bristol scout the prop seems to be rotating - how did you do that???
I aimed a fan at it. To get it to rotate freely enough for this to happen I hollowed out the shaft of the engine by drilling it with successively larger drill bits until I could push a dressmaker's pin down it. The prop was drilled through to allow a length of brass tube (with an inside diameter large enough for the pin to fit through) to be push-fitted into it. The pin is glued into the engine. The friction between the polished pin and the brass tube is so low that the prop will turn with the slightest blow.
Offline Squiffy
« Reply #181 on: April 27, 2015, 05:42:47 AM »
That is a lovely Scout. Who was the kit manufacturer? The standard of your models is amazingly high especially considering the speed that you build them.
It's from MAC Distribution. Prezemol has built one if you want to see an 'under construction' and his is far nicer than mine.
WarrenD
« Reply #182 on: April 28, 2015, 10:09:39 AM »
Most excellent Squiff!  You are a "machine" sir!
« Reply #183 on: April 28, 2015, 12:59:32 PM »
She's a beauty, Squiffy!  Man, you're a modeling machine!
What My Amigo said ! A very Talented Machine!
Offline Thumbs up
« Reply #184 on: April 28, 2015, 07:01:33 PM »
"Gonna need a bigger ceiling".
Offline Squiffy
Re: Squiffy's Kites: 1/72 Aviatik (Berg) D.1
« Reply #185 on: May 05, 2015, 02:11:56 AM »
I think it's going that way!  ;D
Here's one I've had under construction for several weeks, on and off, but have now completed. It's the Eastern Express kit of an Aviatik (Berg) D.1. The struts are very thin and fiddly and there didn't appear to be any positive location of the lower planes into the fuselage, so I had to estimate their position, drill the fuselage and pin and glue them.
The kit wheels were awful! Too fat and with overly large moulded spokes, so I replaced them with a pair from a Fokker D.VII. Maybe not to the purist's taste but it looks better for them, IMHO.
The colour scheme and lettering is that of Oblt. Frank Linke-Crawford.
« Last Edit: May 05, 2015, 02:29:06 AM by Squiffy »
Offline ondra
« Reply #186 on: May 05, 2015, 02:19:28 AM »
Very nice Berg, Squiffy, as I built one myself I know what a difficult and complex design it is and I really like your build.
Linke-Crawford's kite is one of the most discussed Aviatiks and if you ask 4 experts you get 8 opinions on the colours. :)
I have to say you did a great job with the decals, they fit very nicely.
« Reply #187 on: May 05, 2015, 03:16:47 AM »
I couldn't agree more, Squiffy!  Marvelous addition to your collection.
« Reply #188 on: May 05, 2015, 06:47:11 AM »
Nice job Squiffy! You'll have to start using more ceilings at this rate....
WarrenD
« Reply #189 on: May 05, 2015, 09:26:07 AM »
What Ondra said, except I haven't built one. Too scary! :)
Re: Re: Squiffy's Kites: 1/72 Aviatik (Berg) D.1
« Reply #190 on: May 05, 2015, 04:56:41 PM »
Fantastic, Squiffy I love your massive production of tiny planes, without losing in quality!
Bravo!
Antonio
« Reply #191 on: May 05, 2015, 05:18:18 PM »
Another little gem and no mistake. The quality of your builds is excellent especially as you complete them so quickly.
Another on for the airfield in the sky - have you thought of an extension to the house?
Offline Squiffy
Re: Squiffy's Kites: 1/72 Junkers J.1
« Reply #192 on: May 13, 2015, 05:55:00 PM »
Thanks, chaps!
I've begun to build a small diorama, on which to show my German crates. At the moment all it consists of is a strip of grass mat and a half-finished hangar...
The Junkers J1 isbuilt from an Eduard that I purchased from Scott.
« Reply #193 on: May 14, 2015, 07:02:48 AM »
Another lovely model. Those Junker designs did look ugly, although they were very effective.
Offline Squiffy
Re: Squiffy's Kites: 1/72 Martinsyde F.4 Buzzard
« Reply #194 on: May 17, 2015, 05:09:11 AM »
"By God! She's even faster than the S.E.5a - and a pair of synchronised Vickers too!"
