Author Topic: WNW Roland CII Kasta 8, Kogohl II, mid-late1916  (Read 5373 times)
Offline GrahamB
« on: May 17, 2014, 02:35:49 PM »
Hi,
well here it is. A lovely autumn day here has kept me away from the workbench and computer. I have mounted it temporarily in some shots on a Taurus trestle (unpainted) to get a feel of the diorama setting.
The WNW Roland was a thoroughly good kit and in the hands of a real expert more could be done with it  than I have (the basics). There were no real problems with the build and construction although I am wary of some of the decals - upper wing crosses and the port-side fin decal.
Points to watch:
if doing the diagonal laminates on inner surface choose thinner paper than bog-standard printer paper
if doing the tubes for the rear rudder cabling attach them to the sides after installing the observer's seat
if using part E12 increase the angle of the handle as it might foul the wing root tabs otherwise (or leave off completely)
don't forget the oil tank A20 before closing left and right frames!
if doing a breather pipe on the radiator header tank drill out a hole for this before attaching to the engine (even if not adding the tubes at this point)
watch out for possible problems with upper wing cross panels and decal 19 (or 16?) on left side of fin.
watch out that any decal sitting over the port footstep (15, 22, 58 or 68) settles properly into it.
if using the flare holders (D19) paint the inner top strip (wood?)  - I forgot one side but they can be seen through the windows.
So - a 'white and blue' Roland consistent with many photos (in my opinion) and my German namesake Karl Vogel.
Altogether a wonderful kit and a big step up from the 1960's Airfix! THOROUGHLY RECOMMENDED!.
 I'm really tempted to do another - the Hippel 3645/16 Beobachter Schule Koln version in the CIIa kit looks the business - not a cheesy sharkmouth. A great diorama of a similar aircraft on last page of the Datafile too.
Many thanks to all! Let's see yours now!
GrahamB
Offline kornbeef
Re: WNW Roland CII Kasta 8, Kogohl II, mid-late1916
« Reply #1 on: May 17, 2014, 03:21:21 PM »
Graham
Lovely work, a nice different interpretation too. Glad you are not scared to think outside the box.  :)
I'm sure more than a few members will thank you for the tips.
Keith
« Reply #2 on: May 17, 2014, 03:47:36 PM »
What a beautiful piece of work Graham and thank you for the list of building tips.
« Reply #3 on: May 17, 2014, 04:55:54 PM »
Excellent!
Well done Graham and thanks for the tips  ;)
Offline justin1980
« Reply #4 on: May 17, 2014, 05:31:00 PM »
Fantastic finish Graham, co really like the scheme.
Justin
Bessie Braddock: Sir, you are drunk.
Churchill: Madam, you are ugly. In the morning, I shall be sober!
Nancy Astor: Sir, if you were my husband, I would give you poison.
Churchill: If I were your husband I would take it.
« Reply #5 on: May 17, 2014, 10:47:24 PM »
Graham,
   Very nice work throughout, and like many here I like the scheme you chose, and did so well. A Model to be proud of.........well done!
Offline LindsayT
« Reply #6 on: May 17, 2014, 11:59:52 PM »
Great work, Graham! Really well done.
Lindsay
« Reply #7 on: May 18, 2014, 02:13:19 AM »
Really good model there - certainly a step or two up from the Airfix kit! If you do build a second as you suggest make sure you post the photos - they will be worth looking forward to.
« Reply #8 on: May 18, 2014, 02:22:11 AM »
You have make a very great build and paint. It looks wounderful Graham.
« Reply #9 on: May 18, 2014, 02:58:55 AM »
You have really out-done yourself, Graham.  Congratulations on completing
the Walfisch beautifully.  Also much appreciated is the points to watch out
for, a great help for others.
« Reply #10 on: May 18, 2014, 04:44:40 AM »
She's stunning, Graham!  Congratulations on such a gorgeous result.  Thanks for the tips on the build.  I'll refer to them when I build mine.
Offline Epeeman
« Reply #11 on: May 18, 2014, 07:20:37 AM »
Nice one, Graham!
I think you must be one of the first to complete one of these.
Offline stefanbuss
« Reply #12 on: May 19, 2014, 04:01:02 AM »
Stunning. Very well done. And thank you for highlighting things to watch out for.
Stefan
Offline Mark
« Reply #13 on: May 19, 2014, 04:47:04 AM »
Graham,
Wonderful model, stunning finish, and evocative basing!
Mark G.
Offline Russell
« Reply #14 on: May 19, 2014, 07:04:36 AM »
I'd decided to do the 'spots' version myself so this build has provided a lot of valuable information & inspiration.
Russell
