Author Topic: Trumpeter 1:32 Me 262 A-2a  (Read 5445 times)
Offline Ian from Doncaster
« on: May 12, 2014, 07:44:22 AM »
Having finished the Tripe, I didn't want to get out of the modelling "zone" but I fancied a change from WWI and so I started this one out of the stash.
Loads of online references for detailing, photos etc, but I will only do a bit extra such as the wiring behind the instrument panel etc. Otherwise will be OOB.  The references can be conflicting between painting schemes etc.  Also RLM 02 has about as much debate as PC10!  I will use a bit of artistic licence with interior structures such as the undercarriage bays, where the debate is between plain aluminium and RLM 02.
I made the cockpit module, which itself was quite straightforward.  Took my time to take the instrument panel but it looks ok ish.  The instrument faces are on a film sheet behind the front piece.  Wire is fishing line painted yellow - at least this is where the references agree, wiring was yellow.
Offline vincentm
Re: Trumpeter 1:32 Me 262 A-2a
« Reply #1 on: May 12, 2014, 08:07:08 AM »
Very nice start. This is a bird I'm more used to, as WWI is quite new to me. I also think I will "relax" on some WWII bird when I've completed my Albatros...
The foremost glass on the ReVi gunsight is actually a retractable sunshade glass. You may want to paint it with a clear dark green paint to get something more realistic. In normal use, this piece of glass was usually lowered.
« Reply #2 on: May 12, 2014, 08:12:13 AM »
Superb job on the cockpit, Ian.  The wiring really brings it to life.
The 1/32 scale allows for amazing detailing. Well done!
« Reply #3 on: May 12, 2014, 05:13:27 PM »
Thanks for the tip, I can do that before everything gets closed up.  The instructions are OK, but not a patch on WNW.
I'm a bit out of the comfort zone with this one.  I tend to choose my non-WWI kits for aesthetic reasons, ie I like the look of the aircraft, rather than any particular historic reason, therefore strict historical accuracy isn't too important.  However I would like to build the best model I can...
« Reply #4 on: May 12, 2014, 08:45:36 PM »
Super work Ian.
Is there any other aircraft which has a more wonderfully stylish side profile and yet such a disappointing plan view?
« Reply #5 on: May 12, 2014, 09:20:36 PM »
Thanks Nigel.  This aircraft was called "Schwalbe" meaning Swallow, but I could perceive it more as a shark, following the shape.  Sharks don't fly, however.....
« Reply #6 on: May 13, 2014, 01:56:18 AM »
Hello Ian:
Trumpeter has come a long way since hitting the street years back.  The office work looks good thus far.  Enjoy.
mike in calif
« Reply #7 on: May 14, 2014, 04:59:22 AM »
Nice work so far. Def one of trumps better efforts.
« Reply #8 on: May 14, 2014, 12:14:46 PM »
Looking great! There was one of these in My LHS for a couple of years at a very reasonable price. I was TEMPTED but didn't pick it up.... wish I had!
Offline mc65
« Reply #9 on: May 14, 2014, 10:24:35 PM »
beautiful plane.... full of toothish defects, in particular with engines, but far ahead of its time, actually!
about the wheels bays, as far as I know, all the avio alu production was primed, thus to prevent the fast oxidation of the alloy. it's true that in the war's last stages happened all sort of shortenings in production and standard, but I suspect that in the so structured WWII germany there where not chanche to unfinished furniture to leave from a farm to an assembly line... my two cents, obviously.
well done cockpit, the lower part of the rudder pedals maybe ask for a black wash, those three holes had nothing, behind.
about the shape of this machine... well, I also see in it a shark. considering that the difference between aerodynamics and hydro it's "just" the density of the media, we may assume that sharks fly, at the very end! ;D
« Reply #10 on: May 24, 2014, 08:01:32 PM »
Thank you everyone, this is coming together slowly but like the WWI models, in stages.  Good point mc65 about the pedal holes, I may do just that - I'll have a look at how the assembly looks to see if I will do that.
I bought a PE set for the external detailing, I found this too late to buy the cockpit detail set but never mind.  I don't always get on well with PE, but this set has a lot of additional panels and bits for the undercarriage bays etc that is not in the kit.  With the WNW Tripe, the PE I bought was mostly expected to replace kit detailing - which in my opinion was unnecessary so a bit of a waste of money.  For this kit, I will use much of the PE as I will leave the bays open.
Latest update is the gun bay.  As this version was a fighter/bomber there are 2 guns, not 4.  I tried to use the PE wiring for the gun control but bending the flat PE into the 3d complex curves beat me.  I had a second go with some painted invisible thread for the wires, but then as the lengths were short, the wires were not flexible enough.  So my 3rd attempt was WNW's rigging elastic, stretched thin then painted yellow and black.  This did flex enough - not as tidy as aircraft wiring should be, and only a representation of some of the wires.
I will leave the gun bay panels open, which is why I wanted to show the wires.  Also, if the panels have any kind of fit issues when closed, leaving them open avoids any gaps or steps that need work to tidy up the fuselage surface.  The fuselage halves come together OK, when pressed together the joins are quite close, and will need little if no filling. In fact it looks like one of the joins is actually where a panel join would go, so that is a bonus.
I decided to overpaint the aluminium with RLM 02 representation, as some aircraft may have had that coating, plus I think it makes a nice contrast and brings out the detail.  There are some metal highlights that are difficult to see in the pics, and I added further tones with a coat of brown-ish darkened Klear.  In the bay ahead of the gun bay, you can see that effect, which was my first experiment (that bay will be covered) and which I thought was overdone, so I used less colouring in the gun bay itself.  I will do the same painting and coating in the undercarriage bays.
« Reply #11 on: May 28, 2014, 02:34:56 AM »
The gun bay looks great! Your wiring has turned out well! I may be joining you with a thread of my own as I expect to get a 1/32nd Meteor F4 from a trade soon.  ;)
Offline vincentm
« Reply #12 on: May 31, 2014, 03:56:30 AM »
You call this "time to relax"?? LOL
Beautiful job, I like the gun breech color.
« Reply #13 on: May 31, 2014, 04:17:58 AM »
Wonderful modelling on one of my favourite German WW2 types.
Offline IFF1418
« Reply #14 on: May 31, 2014, 06:48:49 PM »
Hello Ian,
Wonderful cockpit and detailing. Guns are magnificent. Great start!
Kind regards
Patrick
