Author Topic: sun-bleached weathering  (Read 2891 times)
« on: April 22, 2014, 07:12:49 AM »
I'm in the process of building a 1:72 Bristol M1.C which I will finish as C4096 of 150 Sqn. in Macedonia. I've assumed a Middle-East reddish brown colour but it's very bold, and I want to tone it down a little to look a bit more sun-bleached. I've not done much in the way of weathering before and would like some suggestions as to how I might achieve this. I have an airbrush, and I have pastels, so use of either has been contemplated, but I'm not sure if a simple blow-over of white, or white pastels will achieve the look I want, or whether that will look like what it is - just a blow-over of white!
Re: sun-bleached weathering
« Reply #1 on: April 22, 2014, 07:48:12 AM »
one thing to keep in mind is that different pigments fade differently given exposure to UV. Reds tend to be the most fugitive.
« Reply #2 on: April 22, 2014, 10:02:25 AM »
That's half the problem, Bo. Obviously the red and blue on the roundels will also have to be faded!
« Reply #3 on: April 22, 2014, 10:58:09 AM »
Maybe some inspiration
« Reply #4 on: April 22, 2014, 11:10:18 AM »
An overspray of the "Dust" finish from whatever paint line you prefer has always provided a nice faded look for me.  Experiment first though.
Offline kornbeef
« Reply #5 on: April 22, 2014, 03:48:59 PM »
Don't whatever you do use straight white. pale sand, grey or pastel shades of whatever colour you are fading will work.
White as you say will look white and false.
Keep it thin keep it subtle and concentrate more on edges than whole panels.
That's my thoughts
Keith
« Reply #6 on: April 23, 2014, 12:42:59 AM »
Tamiya Buff thinned 80% thinner to 20% paint
Buff does a great job of fading areas. Being frugal with the paint % helps you build up the layers to your desired effect... Simples!
Good luck
Buffy the Buckle Slayer!  ;D
« Reply #7 on: April 23, 2014, 11:29:06 AM »
Gentlemen, thank you for your suggestions! I will experiment and update the build log with the results.
