Author Topic: Primer help please!!!!!!  (Read 3280 times)
flygilmore
« on: April 14, 2014, 11:09:02 PM »
I am starting a 1/72 Fokker Dr1 and had to get rid of that yucky red plastic.  I am going to be both airbrushing and brushing MM enamel paints on this model.  On Sat. evening around 9pm. I gave two light coats of Testors enamel primer (gray) out of a spray can onto both sprues.  Before doing the primer, I sprayed 91% Alcohol onto the sprues and wiped them dry then used my heat gun to further dry any tiny crevices. No runs, puddles etc. and it covered very well with pleasing results.
While the parts look and at first touch feel dry/cured, as of last night, I could still take a fingernail and pretty easily scrape the primer off the plastic and if I held the sprues in one spot for a while, I could feel some gumminess and it would leave some gray on my fingers. I read somewhere that the alcohol I used could be preventing the primer from curing completely or does it take 36-72hrs. like other enamels to fully cure?
I am a newbie and haven't built a models since I was a kid so have a lot to learn.
Thanks!!
Re: Primer help please!!!!!!
« Reply #1 on: April 15, 2014, 12:38:13 AM »
I'm not a chemist, but I can't see how washing the plastic with isopropyl would inhibit the enamel primer from curing. Give it a few days...
« Reply #2 on: April 15, 2014, 07:47:41 AM »
The only thing I can think off is that the spray can was not shaken enough before use, apart from that there is no reason for the paint not to dry in the usual time frame.
Offline Ian from Doncaster
« Reply #3 on: April 15, 2014, 09:02:09 PM »
I use a plastic primer from a rattle tin from the auto store (in the UK Halfords is a nationwide chain) which dries in about 10 minutes.  It can be a bit rough, but nothing a smoothing off with micromesh won't fix.
Offline kornbeef
« Reply #4 on: April 15, 2014, 09:10:41 PM »
Tamiya for me. seems to cover nice and thin.
« Reply #5 on: April 15, 2014, 09:27:04 PM »
Me too. It comes in an extra fine grade too.
flygilmore
« Reply #6 on: April 17, 2014, 12:58:59 AM »
Well, went ahead and ordered a Tamiya fine surface primer in a rattle can.  Hopefully I will be really pleased with it.
Thanks.
« Reply #7 on: April 17, 2014, 01:06:07 AM »
I think you will. Here's a tip: heat the can by soaking it in hot water (not boiling, but good n' hot, 140F or so ) for a few minutes before you use it. Obviously keep water out of the nozzle area. A pint sized glass works pretty well.
The heated paint will spray more finely.
« Reply #8 on: April 17, 2014, 01:55:22 AM »
I think that is a good tip for any rattle tin, the paint seems to flow better when warm
« Reply #9 on: April 17, 2014, 03:37:19 AM »
yes indeed applies even to painting your lawn furniture :)
« Reply #10 on: April 17, 2014, 03:50:43 AM »
My primer if choice is Tamiya fine in a rattle-can.  Extremely smooth and
easy to use.  Best to use outdoors, if you can.
Offline treadhead1944
« Reply #11 on: April 19, 2014, 12:01:46 PM »
Humidity and air temperature can play a big role in paint curing. Colder weather can slow down the evaporation of the solvent, creating the situation you are experiencing.
« Reply #12 on: May 04, 2014, 01:41:12 PM »
i gotta give another thumbs up on the tamiya fine surface primer in the rattle can, i use this for a prime after its built and ready to paint this gives you a uniform base to work with. i always prime photoetch with it too. some applications i use auto primer, either filler or sandable mainly for scratching wings and such.
