Author Topic: Washing Parts  (Read 16356 times)
Washing Parts
« on: May 17, 2012, 09:16:42 PM »
Simple question -- Curious how other folks wash parts out of the box. I've always used ordinary dish soap in Luke warm water, but I am wondering if there might be a better way?
Re: Washing Parts
« Reply #1 on: May 17, 2012, 09:46:46 PM »
To tell you the truth Tony, I have never washed a part. I open the box then start painting, and up till now I have had no problems at all with the paint not sticking.
Re: Washing Parts
« Reply #2 on: May 17, 2012, 10:06:55 PM »
I never washed my parts when I built AFV models exclusively, but with the extensive masking required for aircraft models, I do it for them. I haven't had any problems with masking tape pulling up the paint on any of my previous builds but I neglected to wash the wings of my current S.E.5a project and I attribute that to my paint peeling issues when executing the rib shading. I can't come up with any other explanation.
I just use dish detergent and warm water too.
Re: Washing Parts
« Reply #3 on: May 17, 2012, 10:28:41 PM »
   Me too, luke warm water, a few drops of Palmolive dish soap, soak for 10-15 minutes and a good rinse. I then lay the sprues out on a towel to dry. Never had a "peeling" problem.
Lance :)
Re: Washing Parts
« Reply #4 on: May 18, 2012, 12:07:08 AM »
  I wash all my parts in warm soapy water.The larger parts also get the brush treatment while the smaller get the finger treatment (scrubbed between two fingers). Years ago I was told this needed to be done in order to remove any release agent present on the plastic,but I'm really not convinced this is so. Resin kits or parts are a different story though. The main reason I continue to wash all the bits and pieces is to remove all the dust from my sanding operations so that I have a clean surface to paint.
 I should note that when I'm building up a short/limited run kit I have on occasion noticed the plastic itself having an oily texture to it. I'm not sure if this is a release agent or the mark of low quality materials. At any rate you'll need to remove it before attempting to paint. In the past I've had to resort a light wipe down with lighter fluid followed by a wash.
Re: Washing Parts
« Reply #5 on: May 18, 2012, 12:29:49 AM »
I use Muc-Off motorbike/Cycle cleaner. Once the plastic is dry paint sticks to it like fresh cow dung to a blanket  :P
Von Mucky
Offline Jim52
Re: Washing Parts
« Reply #6 on: May 18, 2012, 12:42:29 AM »
I see that someone has spent some time in the country! :D :D :D
Jim
Re: Washing Parts
« Reply #7 on: May 18, 2012, 06:36:06 AM »
Jim
Jim,
 I dream of living the country life  ;)
Von stuckinanurbanjungle
Re: Washing Parts
« Reply #8 on: May 20, 2012, 11:21:48 AM »
I find paint sticks to clean parts like snot on a screen door......I found the eastern European kits have more release agents so I wash them more thoroughly with soapy warm water.
Re: Washing Parts
« Reply #9 on: May 20, 2012, 03:26:43 PM »
i have never washed an injection molded kit. when i started fooling with my karaya ansaldo balilla resin kit it looked a bit greasy so i washed it, ive never had any problems except a few times when i tryed to mask a something the paint lifted off in a couple spots. maybe it is because i didnt wash them but i dont really know. i find that enamels stick better. most of the time you can scratch off acrylic paint with a fingernail but i still use it sometimes for certain things.
Offline Trackpad
Re: Washing Parts
« Reply #10 on: May 21, 2012, 09:15:41 AM »
  I wash all my parts in warm soapy water.The larger parts also get the brush treatment while the smaller get the finger treatment (scrubbed between two fingers). The main reason I continue to wash all the bits and pieces is to remove all the dust from my sanding operations so that I have a clean surface to paint.
I'm with Gregory on this. I'll give the parts a good wash and air dry before starting the build, then a wipe down with a clean cloth and rubbing alcohol before the paint stage: gets fingerprints, dust, spilled ice cream and warm beer of the model!  :D
Cheers!
Offline Fathom
Re: Washing Parts
« Reply #11 on: May 30, 2012, 09:41:52 AM »
I worked for a while building boats so I know about the necessity of mold release agents and waxes. Here in Connecticut I use a product named "Westley"s Bleche White". It comes in a pump spray bottle and is intended to restore white wall tires to a like new appearance. I place the sprues in a shallow tray and give them a good spray, allow them to sit for a few minutes and then thoroughly rinse them a couple of times.
After this treatment, there is a noticable differance. The surface sheds its sheen and no longer feels at all slippery. I have noticed no loss of any detail. Now let's paint.
Fathom
Offline Pete Nottingham
Re: Washing Parts
« Reply #12 on: May 30, 2012, 06:05:28 PM »
  I wash all my parts in warm soapy water. The larger parts also get the brush treatment while the smaller get the finger treatment
But what do you do with your models Gregory?  ;D ;D ;D
Pete.
Re: Washing Parts
« Reply #13 on: May 30, 2012, 09:50:11 PM »
  Pete,
LOL I'll never tell.
"He's a clean old man"
Re: Washing Parts
« Reply #14 on: May 30, 2012, 10:26:50 PM »
  Pete,
Gregory, I hope the brush treatment is a soft brush, not a hard scrubbing brush.  :'(
Pete.
