Author Topic: Airco DH 1A conversion 1/72 scale  (Read 14103 times)
Re: Airco DH 1A conversion 1/72 scale
« Reply #30 on: May 15, 2014, 08:30:00 AM »
Evening All,
Thanks again to everyone for the supportive and encouraging remarks. I am honoured that such compliments have come from modellers who regularly post models of the highest quality and whose work I greatly respect. I do hope that some of you will give one of these pushers a try in the future: as I hope to show here they really are stronger than they look, even in the construction stage. I started the next stage by gluing the booms to the wings and the horizontal tail unit (as described in the FE 2b build), with epoxy glue and allowed them 24 hours to dry out. The lower surfaces, nacelle sides and wheel discs were clear doped linen, the top surfaces and nacelle nose, top and rear of the underside were PC 12. In fact it is not certain whether DH 1A's were painted in these colours according to C. Overs in the DatatFile, but Munson shows this colour in his illustration, and I think it reasonable that some covering would have been used particularly in the desert sun. The ammunition boxes, booms, fuel tank and tyres were grey. The struts were natural wood.
While I thought that posting photos of paint drying would not be too interesting I did think that some people would like to know how I paint roundels (cockades) by hand. I start by scribing circles equivalent to the outer diameter of the roundels on the wings using a pair of dividers. I then paint two coats of white paint inside these circles, allowing the paint to run into the grooves and so make a clean sharp edge. Then I scribe the inner rings of the roundels with the dividers.
The above image shows the rings scribed on the top wing and the blue outer painted in. This was too dark so I painted a second coat of lighter blue over this before the red centre was painted. By using a fine brush very clean rings can be achieved and no touching in was needed. The rudder stripes were hand painted and the serial came from Almarks.
When that the wings, nacelles and tail surfaces were complete the assembly continued. I cemented the four outer wing struts into the holes on the lower wing. (The struts came from the DH 4). Then I put small drops of glue into the holes in the upper wing and carefully lowered the top wing on to the lower wing and rudder. I inserted the pin on the bottom of the rudder into the V of the lower boom where I held it with superglue, and the top of the rudder was cemented to the rear of the fin on the horizontal tail surface. This assembly was allowed to dry out overnight. This assembly is actually much stronger than it looks and allows considerable amounts of (gentle) handling as you insert the remaining struts. I have used this method on all of my pushers so far and not had a problem with it.
When it was dry I added the inner wing and cabane struts first, followed by the boom struts. On the starboard forward cabane strut I added a wind generator made from scrap 30 thou card, and on the port forward cabane strut a fuel pipe from the fuel tank to the top of the nacelle.
I cut two sets of undercarriage legs from 30 thou card and shaped them to aerofoil section. I cut a small extension to the bottom of the legs so that I could put in the small curved section which supported the axle. The DH 4 axle was used without modification, as were the wheels. The legs were glued to the fuselage and the axle between the legs and they were painted PC 12. I cut a tail skid from card but did not glue this or the wheels as I will wait until the model is rigged as they are easily damaged. Finally I added the control horns to the fuselage and flying surfaces - these were from scrap 15 thou card.
The next task will be to rig the model and add the final details. I will post these when the model is complete.
Thanks for looking.
« Last Edit: July 05, 2017, 05:51:14 AM by lone modeller »
« Reply #31 on: May 15, 2014, 03:00:20 PM »
Quite a few giant leaps you have taken LM, the wings look great and the booms fitted extremely well, your painting and painted markings are superb, I'm looking forward to seeing the rigging.
« Reply #32 on: May 15, 2014, 08:36:28 PM »
Thanks LM.  Seeing your lovely DH-1A take shape makes me smile. ;D  Just beautiful!  Very fine work.
« Reply #33 on: May 15, 2014, 09:18:55 PM »
LM you make an exellent work.
Offline justin1980
« Reply #34 on: May 16, 2014, 12:54:11 AM »
Impressive work LM, looking good.  Not something I will try, one DH2 in the stash is enough for me!   :D
Bessie Braddock: Sir, you are drunk.
Churchill: Madam, you are ugly. In the morning, I shall be sober!
Nancy Astor: Sir, if you were my husband, I would give you poison.
Churchill: If I were your husband I would take it.
Offline Old Man
« Reply #35 on: May 19, 2014, 12:03:39 AM »
Most impressive, Sir!
Looking forward to seeing this one brought to a finish.
Excellent work!
« Reply #36 on: May 24, 2014, 06:44:48 AM »
Evening All,
Thanks again for the complimentary remarks, they are much appreciated. I wanted to finish this one this week as I have to go away next week and I do not like leaving models almost finished - I am constantly thinking about them otherwise.
 I used the same procedure to rig this model as I used with the other pusher conversions that I have made. I started with the cabane strut wires, then the front/rear wires between the wing struts; the wires along the rear of the wings, then the front of the wings; undercarriage, booms, tail bracing and control wires; wing control wires and last the anti-drag wires at the rear and then the front. If you are systematic and work on one side of the model and then do the same set of wires on the other side for each stage you should avoid leaving any out. Some people I know tick them off on the rigging diagram. I used copper wire held with superglue. The tail skid was added as the last item during the rigging process to stop it being knocked off.
         The final details were the propellor, wheels, underwing skids, machine gun mountings, a machine gun and cartridge bag, and a windscreen for the pilot. On some machines the observer had a two-piece clear screen that folded downwards and forwards but on many aircraft this seem to have been removed, so I did not include it on my model.
I have posted some pictures in the completed models section for those who wish to see more.
This was the last of the six pusher conversions that I set out to build over 30 years ago (but stopped after about 6 months and then left a 30 year gap!). They represent (with the Revell DH 2) all of the pusher types that saw front line service with the RFC/RNAS during WW1 and I wanted to build them as pushers do not seem to feature greatly in most model collections of this period. I also wanted to see how difficult they would be and was surprised by the answer: not very, certainly not much more difficult than the Revell DH 2. Although there is more rigging on these than some aircraft it is not more difficult. Now I will push off and think about what to do next - probably a kit for a change.
« Last Edit: July 05, 2017, 04:49:42 AM by lone modeller »
« Reply #37 on: May 24, 2014, 08:38:16 AM »
I have enjoyed watching your progress on this one! Final assessment: WOW and then some!
« Reply #38 on: May 24, 2014, 01:06:49 PM »
Beautiful work LM, another fine pusher to add to the collection.
 I totally agree with your comments about pushers not being in many collections. I also have a desire to build them but I want to get my skills up to scratch first! My stash includes DH1/1a, DH2, FE2b, FE8, Vickers Gunbus, Voisin III, AGO C.II, and Farman "Shorthorn". I'll be sure to referance your builds when I get to mine.
Offline IFF1418
« Reply #39 on: May 24, 2014, 07:58:10 PM »
Amazing build LM. I can't stop repeating what a respect I have for modelers like you in this scale. Wonderful, stunning work.
Kind regards
Patrick
« Reply #40 on: May 24, 2014, 08:45:05 PM »
Another wonderful job LM!  I really enjoy seeing your pusher builds come to life.  This one is top notch, as usual.  Congratulations on achieving your 30 year-old dream!  Very well done, indeed. ;D
Cheers and huzzas,
« Reply #41 on: May 25, 2014, 03:10:33 AM »
Thanks to all of you for the wonderful comments. I am extremely flattered.
Keep a look out Ian as at some time in the future I also intend to take on a couple more pushers, including some on your list. Your skills are well up to this kind of work though - give one a go. For the moment I am going to give them a rest and try a couple of kits, but then I suspect I will get withdrawal symptoms…...
« Reply #42 on: May 25, 2014, 04:29:12 AM »
An exellent build LM.
