Author Topic: WNW Roland D.VIa with lot's of extra's finnished.  (Read 27152 times)
Offline DannyVM
« on: April 02, 2014, 03:25:39 AM »
Hi everyone,
this is my very first build of a WNW kit, and my expectations are very high, so i will do my best to give this bird a nice look.
When i first opened the box, i was suprised by the content and by the quality of the part's, decals and instruction book.
The guy's from WNW sure now's how to develope and fabricate a excellent kit, great work guy's
Ok, time to start my build progress.
First the engine. I will build this machine :
So, it's got the Mercedes D.III engine with 200 Pk horsepower.
The springs on the kit part where replaced by Taures part's.
And after some work, the engine look's like this
Dry-fit of the resin manifold intake from Barracuda Cast
The spark plug cables are lead wire 0.2 m/m
Ok, not much, but it's a begin.
Greetz
Danny
« Last Edit: September 20, 2014, 10:35:45 PM by DannyVM »
Offline DannyVM
Re: WNW Roland D.VIa with lot's of extra's rigging
« Reply #1 on: April 02, 2014, 03:33:42 AM »
next progress, or should i say, my first mistake with this kit. :o
Thank's to Richard (rsanz, here on the forum), he pointed me out that i used the 160 Pk. timing gear instead of the 200 Pk (wich i use for the model). I had no idea when i ordered the Taurus resin set, that there are differences into the two engine types  :( :( :( ......ok for this mistake i will put myself on water and bread as a punishment :-[ :-[
In front you see the Taurus part. Also the lifters are in the middle of the rocker boxes instead of at the side of the boxes (wich was typical for the 200 Pk engine). The kit part i will use is behind the Taurus part and is correct.
Because of the wrong timing gear, the water pump was placed to far forward so it will conflict with the engine cowl later on.
This had to be solved, so surgery had to be performed.
Removal of the rocker boxes was no big deal, but the springs (Taurus) needed also to be removed because i wanted to use them again.
After this was done with succes and without loss of any of the springs  ;D  the correct kit part was placed together with the springs.
Et voila, this will be much better.
And now, some paint progress on the engine.
The engine was first painted with Alclad aluminium, and after that the rest was brush painted with Vallejo Model color.
Also the manifold intake was painted and received a wash.
« Last Edit: September 08, 2014, 06:14:13 AM by DannyVM »
Online Umlaufmotor
Re: WNW Roland D.VIa with lot's of extra's WIP
« Reply #2 on: April 02, 2014, 03:38:07 AM »
The intake manifolds and carburetor look absolutely realistic.
Very convincing built so far.
Servus
Bertl
« Reply #3 on: April 02, 2014, 03:46:17 AM »
Servus
Bertl
I agree with Bertl.  You're off to a brilliant start, Danny.  Looking forward to more.
« Reply #4 on: April 02, 2014, 03:56:39 AM »
What a super start you've made Danny. I look forward to seeing more of this one.
« Reply #5 on: April 02, 2014, 04:13:44 AM »
Agreed!
Excellent start, Danny.
More please!
VB  ;)
« Reply #6 on: April 02, 2014, 05:43:43 AM »
Me too! VERY nicely done.
« Reply #7 on: April 02, 2014, 05:47:28 AM »
Great start. Lovely aircraft. I will be watching this thread with great interest.
BTW, should not all the cylinders have the red overcompression bands?
« Reply #8 on: April 02, 2014, 06:51:53 AM »
A wounderful engine, Danny.
« Last Edit: April 02, 2014, 07:02:12 AM by radio »
Offline DannyVM
« Reply #9 on: April 02, 2014, 06:55:15 AM »
Thank's guy's for the nice comments ;)
Quote
Maybe yes, i've seen pictures of engines that didn't have these red band's and i've seen engines with red band's on all cillinders, so i think whe can go all way's with this.
The color photo's of the engine in the instruction booklet show an engine with one color band on the first cilinder, so, that's wy i did the same.
Greetz
Danny
« Reply #10 on: April 02, 2014, 10:48:05 PM »
Hello Danny:
You are certainly off to a good start.  You managed to overcome the challenge of redoing part of the engine and it looks fantastic.  There were issues with the length of the rocker assembly by Taurus being off a bit.  It looks like the correction was made and marketed.  Your weathering of the engine really looks the business and it looks like an engine that has seen some service.
Looking forward to the next update.
Offline Dal Gavan
« Reply #11 on: April 04, 2014, 04:39:00 PM »
Brilliant work on the engine, Danny.
Dal.
Offline IFF1418
« Reply #12 on: April 04, 2014, 06:27:42 PM »
Hi Danny,
This is a stunning engine, really fantastic work on it.
Kind regards
Patrick
« Reply #13 on: April 04, 2014, 09:57:28 PM »
Great work on your Engine including the correction! Terrific start on your project!!
Offline DannyVM
« Reply #14 on: April 12, 2014, 07:41:19 PM »
Thank's guy's for the nice comment's  ;)
time to put some more pic's overhere. Today i put some paint on the cockpit part's, in preperation for the wood like  threatment with oil paint.
For the wood i used Light wood XF-78 and for the interior green i used XF-76.
The ammunition box and empty belt box are painted with Alclad Aluminium.
Time to try my first ever wood painting. ::) ::)
All cockpit part's are done, except for the frame with the canvas behind the pilot seat.
Ok, here comes the pic's,
First, fuselage side walls
The pilot seat
And the rest of the cockpit part's
All was done with Burnt umber oil paint.
Greetz
Danny
