Author Topic: Questions for Jasta 5 colors?  (Read 1304 times)
Offline frame
« on: March 29, 2014, 09:47:18 PM »
Hello Gentlemen,
I have some questions about JAGDSTAFFEL 5. Can you help me in identifying the following colors on the scheme below:
1: for metal covers, parts and small details:
-> Is the color gray or gray green?
-> If it is gray if it is equal to the default or is slightly darker?
-> What is the color of the metal parts in fuselage in this case - a gray or grayish green?
2: for camouflage of "Rumey's Devil" ->
-> Does the color of the box under the head of the demon is the same as that of the tail?
Тhank you in advance
Best Regards,
Hristo.
Offline davecww1
Re: Questions for Jasta 5 colors?
« Reply #1 on: March 30, 2014, 05:42:37 AM »
For Jasta 5 gray I use MisterKit German light Gray.  This comes out looking identical to the profiles in the Jasta 5 books from Windsock.  http://www.misterkit.com/catalog/product_info.php?cPath=85_43&products_id=5553&PHPSESSID=nrh4m7mkttf45f8aj38h1fglh3
Also I believe that the green squares on Rumey's African face would have been painted in the same color as the Jasta 5 greentail, since they used what they had at the Jasta level and they must have had a large stock of green paint to paint all of the tails.   so they also must have used the same gray as on the fuselage to paint the upper wing before adding all of the green squares to the wing.
Offline frame
« Reply #2 on: March 31, 2014, 05:11:24 PM »
Thanks for the advice, Dave. Will listen to your guidance.
