Author Topic: Revell 1/28 Fokker DR1 Triplane  (Read 16165 times)
Re: Revell 1/28 Fokker DR1 Triplane
« Reply #30 on: April 05, 2014, 05:53:24 AM »
Good to see others have are still working on this Revell Classic.
« Reply #31 on: April 05, 2014, 06:21:30 AM »
   It's like a trip back in time, Dave, and you are doing wonders with this old classic. Nicely added details and great brush painting, in fact nicely done all around.
Offline Epeeman
« Reply #32 on: April 05, 2014, 07:26:04 AM »
Ed/Lance - thank you both.
I'm really pleased that others like my brush painting - a nice boost during a build.
« Reply #33 on: April 05, 2014, 12:54:22 PM »
Excellent work on such an old model, Dave.  I think the colour scheme you have
chosen to do is great and your brush painting abilities are really good. I look forward
to the next updates. Well done!
« Reply #34 on: April 05, 2014, 01:10:23 PM »
This is coming together very well Dave, your brush painting is superb and you are achieving excellent results, the camo showing through the lovely red is subtle but evident. The underside blue is very nice and the decals look really good, well done so far.
PS, good job with the stitching under the fuselage.
Offline Epeeman
« Reply #35 on: April 06, 2014, 07:42:58 AM »
Ernie and Des,
Thank you both, gentleman - very much appreciated.
Offline Epeeman
« Reply #36 on: April 06, 2014, 09:56:00 PM »
All,
I'm starting to worry I've become a bit of bore on this build (I am getting this one together quickly) so apologies!
However, I did some more work over the last couple of evenings.  I have now painted, applied decals, fitted and rigged the top wing.  Fitting the upper wing proved to be a bit of a challenge - tricky getting the cabane struts to fit (when installed on fuselage the part that attaches to underside of wing were angled and not straight - wing attachment slots are straight) so involved twisting the cabane struts at the top to correctly meet the wing attachment point on the underside.  Got there in the end though - all three wings have aligned beautifully when view from top and bottom.
 However, I have had to settle for a less than perfect fit to the cabane struts, especially on the port side.  Try as I might I could not get then to match the angle of the lower strut already in place.  In the end, settled (after lots of shunting around) for the best fit/angle I could obtain.   I hope it does not look too bad?
So I am now on the 'downhill slide' with this build now - only the landing gear, under wing skids and prop to go!
One thing worth mentioning is the quality of the kit decals.   They are superb - very easy to work with and react especially well to decal setting/softening solutions.   In fact, they put to shame some of those supplied in other, more expensive kits.   I really liked working with them.
More to follow in due course.
« Reply #37 on: April 07, 2014, 12:33:50 AM »
Looks wonderful Dave!  I havn't seen this scheme applied in a while, so it's a nice reminder. ;D  This model really looks like a Dreidecker to me! ;)  Excellent modelling on an older classic kit.
Offline IFF1418
« Reply #38 on: April 07, 2014, 03:05:00 AM »
Hello Dave,
Extremely nice! Well done, one can't see you had some problems. Your color is beautiful.
Kind regards
Patrick
« Reply #39 on: April 07, 2014, 03:21:28 AM »
A very nice painting and build until now, Dave.
Offline Epeeman
« Reply #40 on: April 07, 2014, 06:05:03 AM »
Bob, Patrick and Martin -
Thank you!
Offline Epeeman
« Reply #41 on: April 08, 2014, 07:12:27 AM »
Last update -
A few shots of the landing gear and lower wing skids prior to installing.
All installed
Work on the prop - first view of basic laminated wood colour painted on free hand
Once dried, stained using artist oils - mix of burnt sienna and burnt umber applied then carefully brushed out to (hopefully) give the right varnished colour
View of the completed prop - once oil paint dried (overnight) painted on clear orange then placed decals in place.  Lastly, clear coated using matt varnish and painted boss.
Prop then installed and model completed
Thank you to all those who supported me during this quick build.
« Reply #42 on: April 08, 2014, 08:07:40 AM »
A very nice and good build.
« Reply #43 on: April 08, 2014, 09:12:20 AM »
Hello Dave:
This really turned out nice.  As Martin said, a good clean build.  It is neat to see these old kits worked on and turn out so well.
« Reply #44 on: April 08, 2014, 11:12:39 AM »
Dave,
really nice work on this old Classic. I have enjoyed following your build!
