Author Topic: Nieuport 17 1/48 Eduard Weekend  (Read 9189 times)
Offline kendyman
« on: May 15, 2012, 11:34:53 PM »
This is the Eduard Weekend edition of Nieuport 17 - Reme Dorme.
I had a twisted fuselage, which seems to be a problem for some people, but using strip styrene to fill the gaps and eventually got a good fit. Other than that this was a fun build.
The box art (single Vickers) and instructions (over wing Lewis) didn't match, so I downloaded the Profipack instructions and followed them for a Vickers equipped plane.
Rigging is mainly Ez-Line, with undercarriage done in fishing wire.
Paint is a mix of Tamiya Flat Aluminium/White for plane, and Citadel Chain Mail for cowling.
Wood is Vallejo Dk Yellow + Vallejo Wood Grain.
Ken
Re: Nieuport 17 1/48 Eduard Weekend
« Reply #1 on: May 15, 2012, 11:37:05 PM »
Nicely done. Did you spray the Citadel and if so what did you thin it with?
Offline gcn
« Reply #2 on: May 16, 2012, 12:23:25 AM »
Nicely done. I find the Citadel silvers stomp all over the Tamiya Aluminium in so far a quality of finish is concerned.
« Reply #3 on: May 16, 2012, 12:42:52 AM »
   Ken,
Beautiful Nieuport 17 my friend. The silver looks spot on too.
Offline kendyman
« Reply #4 on: May 16, 2012, 12:48:30 AM »
Hi Steve,
I have a mix of water & "Winsor and Newton Galeria Acrylic Fluid Retarder" at 20:1 which I use to thin the Citadel when both spraying and brushing.
Interestingly the mix also makes Tamiya Acrylics brushable, something I once thought impossible.
Ken
Offline gcn
« Reply #5 on: May 16, 2012, 01:49:58 AM »
I found that using solely W&N flow aid as a thinner with Tamiya acrylics they brushed superbly but unfortunately they never dried. I will try the water bit as well and see how it goes. I have used a water and flow aid mix with vallejo and while it paints easily its not very resistant to any sort of handling.
« Reply #6 on: May 16, 2012, 01:50:52 AM »
Beautiful little Nieuport, Ken.  Thanks for the tip on the W&N retarder.
Offline kendyman
« Reply #7 on: May 16, 2012, 02:02:18 AM »
I've also found the retarder has an adverse effect with Vallejo, for spraying I start with a mix of 3:1:1 of Vallejo:plain water:Revell Aqua Mix and adjust if too thick/thin.
For Revell Aqua I start with 6:1:1 of Revell Paint:Water+Retarder:Revell Aqua Mix.
Offline Pete Nottingham
« Reply #8 on: May 16, 2012, 02:27:09 AM »
Lovely looking Nieuport Ken, beautiful finish.
Pete.
Offline michael
« Reply #9 on: May 16, 2012, 04:26:17 AM »
You must be happy with that Ken! stunning
michael
« Reply #10 on: May 16, 2012, 04:30:05 AM »
Thanx for the paint tips guys!!
Offline Epeeman
« Reply #11 on: May 16, 2012, 07:43:25 AM »
Ken,
Just seen this - well done on a very nice, tidy build.
Offline Whiteknuckles
« Reply #12 on: May 16, 2012, 09:49:26 AM »
Nicely done Ken - she looks lovely!!
Eternal Apprentice
« Reply #13 on: May 16, 2012, 09:52:05 AM »
That is a lovely looking Nieuport Ken, very well done.
« Reply #14 on: May 17, 2012, 01:33:58 AM »
Ken
Hallo Ken,
First of all my congrats for the Nieuport, it looks splendid.
On the retarder you quote I have a question: I normally use Tamiya acrylics  by brush and sometimes I have problems, what is the effect "Winsor and Newton Galeria Acrylic Fluid Retarder" has on those colors?
You mix 20 parts of Retarder to 1 of color or the other way round?
Thanks for informing
Antonio
