Author Topic: Eduard Pfalz D.IIIa, double strike  (Read 8296 times)
Offline KrzysiekK
Re: Eduard Pfalz D.IIIa, double strike
« Reply #15 on: March 17, 2014, 08:06:05 PM »
and again,
I took care of the wings form Jasta 5 Pfaltz as the final layer is to be silver I tried some preshading, gently at the beginning…
it does not look so good,  I have decided to improve ribs and ailerons visibility and stopped somewhere here, as do not have any further idea how it should look like at the end:
the ribs masking:
finally:
regards
K
Offline IFF1418
« Reply #16 on: March 17, 2014, 08:23:17 PM »
Very nice, wonderful engine and interior, great shading!
Kind regards
Patrick
Offline Adam
« Reply #17 on: March 17, 2014, 11:58:32 PM »
Your shading method looks great. Soon I will be paint wings of my Fokker E.II. I will try use your method. Can I?  ;)
Adam.
« Reply #18 on: March 18, 2014, 01:19:57 AM »
Krzysiek, you are making good progress on the Pfalz.  Your masking work and
shading is first-rate. Nicely done!
Offline KrzysiekK
« Reply #19 on: March 24, 2014, 10:07:37 PM »
Adam.
it is not my method, I just copy that from somewhere else ;D. Adam, can not wait for your updates with Fokker E.II ;)
ok. Barely finished those wings…that was really tough issue to be done and hope that results will be worth of doing them
Lower wing:
and both
regards
K
Offline KrzysiekK
« Reply #20 on: April 03, 2014, 06:22:17 PM »
Degelow got his wings done as well..frankly doubt if all which was done will be visible after final black layer, but you never know until try
regards
K
« Reply #21 on: April 03, 2014, 06:31:42 PM »
Great efforts, Krzysiek. I wish you, that they are not in vain. Anyhow, my experience tells me, that postshading is much more effective.
Offline IFF1418
« Reply #22 on: April 03, 2014, 06:46:24 PM »
Hello Krzysiek,
Exceptional work on the shading. Looks really great! Keep on this good work!
Kind regards
Patrick
Offline Jacek
« Reply #23 on: April 04, 2014, 04:16:44 AM »
I am very curious of the final effect.  ::)
Offline Dal Gavan
« Reply #24 on: April 04, 2014, 04:27:09 PM »
I'm really interested in seeing how the shading turns out, Krzysiek.  It's a technique I haven't mastered yet, but with two RFC planes under construction, I need to work out how to do it pretty quickly.
Good stuff.
Dal.
« Reply #25 on: April 04, 2014, 10:14:36 PM »
Great work on your shading so far. Like the others I am looking forward to seeing the final results!
Offline KrzysiekK
« Reply #26 on: April 07, 2014, 09:19:50 PM »
ok guys, here we have the reults
I have painted Jasta 5 wings Vallejo alu with little bit of grey and have some doubts about the outcome.
The fact is that, depending on the gaze angle with same light, the effect is quite different. IMHO the ribbing is too visible right now and should be more integrated into the overall picture of the wings ...  The color of the canvas sometimes breaks through the aluminum and that effect found really interesting.
To sum up all preshading work was really tedious and monotonous, the final result only slightly captures the workload done. Nevertheless It was worth a try
regards
K
« Reply #27 on: April 10, 2014, 09:44:39 AM »
Nicely done effect!
Offline KrzysiekK
« Reply #28 on: April 15, 2014, 10:12:53 PM »
Hi,
Little update In case of Jasta 5 bird. Now we can be sure that it belongs to “Green Tails”
Preshading was done in that case as well and I am happy with the results. One can observe really subtle claret below green, not well visible of photos but it is for sure!!
regards
K
Offline Adam
« Reply #29 on: April 16, 2014, 05:46:07 PM »
Very nice painting, thin strips on the outskirts are wonderful.
Adam.
