Author Topic: Scratchbuilding "saxophone" exhaust pipes in 1/48  (Read 11189 times)
gstaud
« on: May 15, 2012, 09:23:29 PM »
Hi all you veteran modelers.
Coming back to the hobby after many years away and have an old Classic Airframes 1/48 Heinkel He51 b-1 that's been gathering dust.  The only real detail on the engine are the 12 "saxophone" shaped exhausts; unfortunately, the kit supplies ones are pitiful. Wanted to build new ones and am casting about for a way to make them out of brass tubing.  Harry Woodman suggested using ballpoint pen tubing stretched to shape, but I have a feeling I won't be able to replicate the shape (x12).
Aftermarket kits are nonexistent, though some I have found are reasonable approximations.
Any advice would be appreciated.
gstaud
Re: Scratchbuilding "saxophone" exhaust pipes in 1/48
« Reply #1 on: May 15, 2012, 09:35:54 PM »
Does this photo show the exhaust pipes that you are wanting to make? Click the photo for a larger image.
« Last Edit: May 15, 2012, 09:37:31 PM by Des »
gstaud
« Reply #2 on: May 15, 2012, 10:21:37 PM »
Those are the ones.  Kit supplied ones are 12 individual pieces and are lacking any realism, IMHO.
GS
Offline Matt
« Reply #3 on: August 08, 2012, 05:40:52 AM »
Hello
Not easy to reproduce.  I would make one of the existing ones as detailed as possible (open up the end, clean up the shape) and then make a silicone rubber mould and cast the rest in resin.  Laborious but....
Matt
« Reply #4 on: August 10, 2012, 01:29:49 PM »
i was going to suggest the same thing.
