Author Topic: Airco DH.9 (1/32, Wingnut Wings)  (Read 19193 times)
Re: Airco DH.9 (1/32, Wingnut Wings)
« Reply #75 on: April 07, 2014, 10:01:36 PM »
Maybe yours improvement will be looks more natural than original made by WNW on the model.  :)
Adam.
Yeah, I think so... Theirs looks like it was done by a computer...
Offline IvotB
« Reply #76 on: April 08, 2014, 12:23:16 AM »
Hello Przemol,
Your stitching really looks execellent. Far better than the stitching provided by WNW on the fuselage. For the simple reason that your stitching has slightly more depth and is just 98% identical, which makes it better.
I'm afraid that for the best effect, you need to redo the stitching of WNW in the same fashion.
Furthermore, I admire your build. I have one DH9 waiting in my stash. I'm still considering either to build the LVA version or a KLM version. The last version will need some conversion.
regards,
Ivo
« Last Edit: April 08, 2014, 12:30:23 AM by IvotB »
« Reply #77 on: April 08, 2014, 12:28:42 AM »
Hello Przemol,
regards,
Ivo
I have come to realize Ivo is a bit of a troublemaker.  ;D
Offline IvotB
« Reply #78 on: April 08, 2014, 12:32:43 AM »
I do apologise, but it's just admiration of the level of perfection that you are achieving that brings out the worst in me  ;)
regards,
Ivo
« Reply #79 on: April 08, 2014, 03:36:46 AM »
You guys, flatter me too much.
Anyway, I have painted the PC10 and my added stiching indeed has more 3D depth but I reckon that WNW's one with some wash will be similar enough, tough more repetitive. Some photos will come when PC10 is shaded.
« Reply #80 on: April 08, 2014, 06:20:32 AM »
The shading is not done, yet. First I have to paint the national markings and the serial. My first time to use masks exclusively. For the checkboards I am using my own rectangles cut from the masking tape. For the serial I have ordered masks to be cut to the shape I created in a graphics program basing on shapes of digits and letters seen in photos of DH.9. As you see, in all the cases some retouching in necessary. I will cover what I got with a coat of clear varnish, than delicately sand the borders with 2000 sand paper and then will see what else can or should be done.
You can also see my stiching versus the original kit one. I suppose that some wash will make them look one similar enough to another...
Offline DC87
« Reply #81 on: April 09, 2014, 11:21:35 AM »
Really enjoyed admiring the work you have done so far, keep the inspiration coming.
Dan C
Never forget, always remember.
« Reply #82 on: April 10, 2014, 09:43:40 AM »
Beautiful as always!
Offline IFF1418
« Reply #83 on: April 10, 2014, 04:10:46 PM »
Hello PrzemoL,
Outstanding work. The color is just beautiful.
Kind regards
Patrick
« Reply #84 on: May 10, 2014, 04:59:03 AM »
Dear friends, I have to ask your pardon... During the build of this model I became too lazy to take any in-progress photos. And now, when the model is finished I can only report a few additions and issues I had on the way and invite you to the gallery.
Besides what I reported earlier I have added:
1) wiring, fuel plumbing, control rods and few details to the engine
2) spent cartridge collector box for Vickers
3) used Parabellum gun from WNW Hannover kit - oddly this example of DH.9 had the German gun installed, probably they came to Poland without Lewis guns, Vickers guns seem to be visible in the photos
4) radiator drain cock
I had some problems with the cooling water tank and fuel lines between the fuselage and the upper wing - they all came to be too long. I had to shorten them by about 1.5mm. I am not sure why it was so, the cabane struts do not leave any margin of error here.
Also the fit of the carburetter intake pipes was not perfect at all - I had to trim them and to sand delicately the openings in the fuselage sides. Generally, if you look closer to the kit instructions regarding the carbs, there is some contradiction - three nice shots of two variants of carbs do not correspond to what instructions tells you to mount on the engine.
The interplane struts also required some care, the outer ones were very loose in their sockets, the inner ones - quite contrary had very tight fit. I have attached the cabane ones first (one of them was loose, too), put the upper wings on to control the geometry while the glue was setting. Then I repeated the same with the interplane ones.
What is also surprising is the question of longer and shorter plywood sides in the rear fuselage. The kit gives only the short version, while one of kit options - Bonus, just like the one I built, requires the longer version. I have just realised that Ninak kit has both of them. So it is indeed surprising, why WNW omitted this detail here.
This list in by no means meant to be critical. This kit is overall absolutely high quality product, one you grow to expect from WNW. I only mention those issues to give some hints to you, who might like to build your DH.9. Highly recommended!!!
« Last Edit: May 10, 2014, 08:32:20 AM by PrzemoL »
« Reply #85 on: May 10, 2014, 05:08:31 AM »
Excellent, looking forward to the walkaround!
« Reply #86 on: May 10, 2014, 05:25:01 AM »
It really doesn't get any better.  Beautiful work, Prze.
« Reply #87 on: May 10, 2014, 05:37:23 AM »
Great work and painting Przemol.
« Reply #88 on: May 10, 2014, 08:20:25 AM »
Outstanding work as always from your bench! Your painting,weathering, and rigging are always STUNNING!
Offline jknaus
« Reply #89 on: May 14, 2014, 06:17:11 AM »
Beautiful. Really nice work on that. I like all the extra details you added and the painting is great.
James
