Author Topic: Humbrol Acrylics  (Read 2034 times)
IanF
Humbrol Acrylics
« on: January 19, 2014, 08:18:47 AM »
Help please! I have recently started using the Humbrol acrylic range of paints. They claim that they can be thinned by water, but I have found that when being airbrushed they tend to break down. I know that Humbrol sell a thinner, but for the amount you get it seems to be excessively expensive. Does anyone know of a suitable alternative, or am I doing something wrong with the thinning of the paint for airbrushing? Advice please.... >:(
Re: Humbrol Acrylics
« Reply #1 on: January 19, 2014, 08:37:49 AM »
I have never used Humbrol Acrylics but from what I have heard they are excellent for brush painting especially with figure painting. As far as thinning your Humbrol acrylic paints I don't know, but I use Gunze acrylic paints and thin them with lacquer thinners, it works beautifully, that might work with the Humbrol acrylics as well, I use lacquer thinners to thin the Humbrol Enamel paints with excellent results.
Hopefully someone who has used the Humbrol acrylics will step in here.
Offline Misterfriend
« Reply #2 on: January 28, 2014, 02:04:44 PM »
I had trouble when I first started airbrushing with Humbrol acrylics but that was because I was adding a drop or two of isopropyl to them, which is what I normally do when using acrylics. Unfortunately they react very badly to that and clump and clog and just go nasty. Someone over on Britmodeler pointed out my mistake and now i just use water and they work fine. I sometimes add a drop of acrylic retarder. Also i have heard that the quality of them can vary quite a bit so it could be that you got hold of a duff batch.
And i still hate the design of the pots as i always manage to spill more than i get in the cup!
Segan
