Author Topic: WNW Sopwith Tripe - N5376 Black Sheep  (Read 25424 times)
Re: WNW Sopwith Tripe - N5376 Black Sheep
« Reply #30 on: January 17, 2014, 11:11:02 PM »
Nice job! ... Btw sawing the hub off to paint separately is another option... not terribly difficult with the proper saw, just go slow and work around...
Offline Ian from Doncaster
« Reply #31 on: January 17, 2014, 11:41:45 PM »
Thanks folks...
I had considered that Bo, but to take a hub off an unused spare prop from a previous kit and then sand off the Tripe prop hub, paint and join the two together.  I don't yet have the skills to cut so carefully though.
Antonio, the seat was initially painted in humbrol metalcote polished aluminium.  This is followed by thin brushed layers of satin black, ideally to be wholly black as I am hoping to represent a "new" aircraft.  At some places the underlying metal shows through the black paint.  I had tried to replicate how the real seat may have been painted on the metal assembly.  Also, there could be an element of flash reflection..
« Reply #32 on: January 18, 2014, 12:23:01 AM »
Wow  Really nice job of the interior rigging, Ian.  Did you fashion your own
metal attachment points on the rudder bar?  It looks super!
cheers,
Hi Ernie, sorry I missed the question - the rudder bar is the kit part, with the "metal" fittings painted black, but carefully..
« Reply #33 on: January 18, 2014, 01:12:19 AM »
Hello Ian:
Prop and engine look great.  The push rods actually look like metal renderings in the photo, nice job.  The prop is a jewel and your patience with the hub has paid off.  Looking good so far.  Like so many, this is in my stash and hopefully one day.
Offline Dal Gavan
« Reply #34 on: January 18, 2014, 11:10:36 PM »
That prop and donk came out beautifully, Ian.  I really like the colour on the prop, I'll have to try a dark earth base myself, rather than the normal sandy/yellow I use.
Dal.
« Reply #35 on: January 19, 2014, 06:43:03 AM »
Hi Mark, Dal, thank you for the encouragement.
I too like the darker prop - the struts will be lighter for contrast.
A little more progress, the HGW seatbelts are fitted - I have still to tighten the control lines however the floor assembly is now complete.  I moved on to the instrument panel.  To enable a quick job, I used a variety of thin layers of brown paint for the wood, with a few pencil lines, and several coats of Klear.  The bezels and pipes are all hand painted, again as with the prop hub not perfect, but they will do.  I wonder if WNW could make these panels as they are originally, ie a cut out panel with holes for instruments and then drop in the instruments individually.  The compass is an example of how this could be done, as is the rear of the prop boss albeit a thicker component.  I also remember the WNW LVG has inspection covers/vents on the engine cowlings that drop neatly into their locating holes.
After assembly, I noticed that the central compass appeared to be rotated 20 or 30 degrees to the left.  I wondered how this was, as the locating hole and compass fitting point are a tight fit.  I prised the compass off, and found that the semi-circular locating hole itself was rotated, whether this is true for the aircraft or not I do not know, however I will leave it as it is now.
« Reply #36 on: January 19, 2014, 10:11:51 AM »
Brilliant job on the instrument panel, Ian.
« Reply #37 on: January 19, 2014, 12:53:07 PM »
Only about 20 times better than my effort on the panel! Beautiful work!
Offline IFF1418
« Reply #38 on: January 19, 2014, 07:45:02 PM »
Ian this is an extremely well done instrument panel. The nicest I've seen till now on a tripe. Fabulous!
Kind regards
Patrick
« Reply #39 on: January 19, 2014, 10:01:27 PM »
The instrument panel is stunning Ian.  Beautiful work!  Did you make the
pulseometer yourself or is it molded on?  The whole thing looks amazing.
« Reply #40 on: January 20, 2014, 02:56:45 AM »
Thanks folks, but I think my panel is average...
The pulsometer (bottom left instrument?) is the kit molding - I am not sure what this actually is?  I have seen some modellers replace the top part with clear sprue, but I painted the top with a CDL colour then coated with Klear.
« Reply #41 on: January 20, 2014, 03:21:22 AM »
I believe it was to confirm that oil was circulating properly.  The oil would
show in the sight glass.
« Reply #42 on: January 20, 2014, 04:54:57 AM »
Thanks Ernie.  I had looked at a few build logs on here for inspiration!
Looking at this model, the components that seem to bring the whole model together will be the cockpit side frames/cabane struts.  They have to be painted carefully as several components attach, and as the top half of the struts will be external, I ought to use oils for the wood.
In the meantime, I have done a few jobs that only take a little while each.  I painted up the wheels and tyres, shown dry fitted here.  The tyres themselves were pre-painted white where the manufacturer's name is embossed, then after painting grey, the lettering was exposed by carefully rubbing through the grey with fine micromesh.
I painted the rudder too - an experiment really as the decals would be fine, but I knew I could strip the paint if I wanted.
« Reply #43 on: January 20, 2014, 08:57:32 AM »
Grand job of the wheels, Ian.  The idea of bringing the printing out worked
a treat.  Your painting of the rudder is pretty much perfect.  Nicely done!
Offline Zabu
« Reply #44 on: January 21, 2014, 11:56:17 AM »
The instrument panel it's amazing and the rudder looks very good too. Well done.
