Author Topic: WNW Sopwith Tripe - N5376 Black Sheep  (Read 25422 times)
Offline Ian from Doncaster
Re: WNW Sopwith Tripe - N5376 Black Sheep
« Reply #15 on: January 16, 2014, 04:29:33 AM »
Thanks Bud & Mark...
Last night I put the seat assembly together, the control column, rudder bar etc.  This included the internal control lines and floor frame rigging.  The latter was made with 2 strands of EZ line, zig zagged between the frames and fixed at each end with a drop of CA.  I made a tiny nick with a scalpel blade at the bottom end of each frame component in which the EZ line sits, so as not to protrude where the side frames will go.  This rigging could do with painting, and a bit of touch up to the floor itself.
I used steel painted invisible thread for the control lines, and all 10 lines are run through the seat support, to be terminated later behind the cockpit structure.  These lines will be pulled tight as the fuselage is assembled.  I noticed that I have put the elevator control lines from the stick to the top of the pulley, rather than the bottom - too late to change this but it won't really be seen.  The aileron control lines are EZ line hanging loose, and will thread through tiny holes I drilled in the fuselage halves at the lower wing root therefore easily hidden once the model is buttoned up.  I decided not to model turnbuckles as the 'pit is busy enough.
Seatbelts to be added and touch up paint, then I can move on to the side frames.  The oils on the prop are dry enough now for klear coating too.
Not too happy with the photo quality, but with the next update I will try better.  I am much happier with the assembly of this model than when I built the Pup a couple of years ago.  My painting of the rudder bar etc is much more effective - still far from perfect but I can see improvement in my own work.
« Last Edit: January 16, 2014, 04:33:46 AM by Ian from Doncaster »
« Reply #16 on: January 16, 2014, 04:41:01 AM »
Very nice Ian. One for me to save for when I finally get round to my WnW Tripe.
« Reply #17 on: January 16, 2014, 05:17:34 AM »
Really nice work Ian! Your rigging of the interior came out great!!
« Reply #18 on: January 16, 2014, 05:16:20 PM »
Wow  Really nice job of the interior rigging, Ian.  Did you fashion your own
metal attachment points on the rudder bar?  It looks super!
cheers,
« Reply #19 on: January 16, 2014, 05:20:49 PM »
Wow, yet one more Tripehound from WNW!  ;) Great start, Ian. Enjoy it as so many of us already have!
Offline Dal Gavan
« Reply #20 on: January 16, 2014, 10:09:34 PM »
Excellent work, Ian, particularly sorting out the rigging in the pit.  It's looking good.
Dal.
Offline Zabu
« Reply #21 on: January 17, 2014, 06:30:07 AM »
Great start, the engine looks amazing and the cockpit it's nicely done.
Offline IFF1418
« Reply #22 on: January 17, 2014, 05:50:15 PM »
Great interior Ian, Your rigging of the interior is excellent (been there) and is looking great. Looking forward for your next update.
Kind regards
Patrick
« Reply #23 on: January 17, 2014, 08:13:58 PM »
Thanks everyone.  This kit is relatively straightforward so far, touch wood!  And I say that from my perspective as a relative amateur compared to many on here.
Last night I added the HGW fabric laser cut seatbelts.  They went together OK and are now fitted, much easier and "softer" looking than PE variants.  I also finished the prop now the oils have dried for a week, with several layers of Klear and the Clayton and Shuttleworth logo decal on one blade as per the period photo of page 15 of the WNW instructions.
When I painted the prop originally, I had used liquid mask on the hub.  This peeled away nicely and the resultant edge to the wood effect paint where the hub sits, created just enough of a rim type barrier for the steel paint not to over run.  I took care not to spoil the prop with a badly painted hub!  The wood showing through the holes in the hub was then painted with a gloss (acrylic) brown using the end of a cocktail stick, and any excess brown immediately scraped off the hub with the tip of a no 11 blade.  The prop is sat on the engine shaft without glue, just for the pic.  The shaft fits perfectly so I will not need to use any force at all to fit the prop to the engine during final assembly.
Offline IFF1418
« Reply #24 on: January 17, 2014, 08:22:19 PM »
Fantastic how you managed to show the wood trough the hub holes Ian. Your propeller is magnificent. Great work!
Kind regards
Patrick
« Reply #25 on: January 17, 2014, 08:31:35 PM »
I can only echo Patrick's remarks, Ian.  Beautiful rich wood colour on the
propeller.  Superb work, my friend!
« Reply #26 on: January 17, 2014, 09:16:19 PM »
Thanks Patrick and Ernie, I will hopefully manage better photos when we have some decent daylight here!
I would prefer if WNW supplied a hub component separately - this would allow me to do a better paint job, but you can't have everything I suppose!
« Reply #27 on: January 17, 2014, 09:49:23 PM »
Very impressive Ian. I really like the wood tone you have achieved.
Offline LindsayT
« Reply #28 on: January 17, 2014, 11:02:07 PM »
+1! Painting hubs is really tough for me! You've done a great job, Ian!
LT
« Reply #29 on: January 17, 2014, 11:09:52 PM »
Ian what a terrific work so far! I can't imagine the remainder!!!!
 8)
BTW I am very curious about how did you achieve the black metal effect on the seat.
Painting metal is one of my (many) weakpoints still...
Antonio
