Author Topic: Source for miniature wound springs  (Read 2131 times)
« on: December 31, 2013, 04:25:12 AM »
A while back Des used a tiny diameter wound spring for the tachometer cable in his WNW Snipe. I guess that it must be about .5mm OD or maybe even less. Does anybody have a source for these things, preferably US?
--Bo
Offline Beto
Re: Source for miniature wound springs
« Reply #1 on: December 31, 2013, 05:48:45 PM »
Have you tried roundwound guitar string? The smallest size available as far as I know is .017, which translates into 0.43mm. See here:
http://www.stringsandbeyond.com/dniwoelsist.html
Your nearest music shop should have them and a single string will be enough for several squadrons. While at it pick also some unwound .008 strings. (0.02mm)
Offline kornbeef
« Reply #2 on: December 31, 2013, 06:01:01 PM »
Bo.
Have you thought of using metal guitar strings? The spiral wound type.
Heat them to burn out the core so theyre more flexible if needed. I used to use them for valve springs and ribbed hoses in other scales.. Not sure of the smallest dia you can get though.
Keith
Beto posted with better info while I was talking to SWMBO  ;D
« Reply #3 on: January 01, 2014, 04:48:01 AM »
Duh, I have a guitar even. Thanks for the ideas, guys :D
