Author Topic: Still plodding along- nearly finished  (Read 19621 times)
Re: Still plodding along.
« Reply #30 on: July 15, 2012, 06:32:18 PM »
 Dal,
She's one striking kite my friend. Love that color scheme.
Offline Whiteknuckles
« Reply #31 on: July 15, 2012, 06:56:41 PM »
Looking good Dal!!
Eternal Apprentice
« Reply #32 on: July 15, 2012, 07:22:06 PM »
Starting to really look the part now Dal, lovely paint scheme and very well applied, you are on the home stretch now.
« Reply #33 on: July 15, 2012, 09:58:42 PM »
That is coming together to be a pfine looking Pfalz!
« Reply #34 on: July 16, 2012, 03:20:26 AM »
Very striking, Dal.  You're almost there, mate.
« Reply #35 on: July 16, 2012, 04:14:22 AM »
Dal,
   Really an eye catching colour scheme, spectacular actually. Keep on "plodding", you've got a real crowd pleaser almost completed.
Offline Dal Gavan
« Reply #36 on: July 16, 2012, 09:21:36 AM »
Thanks, Gents. There's a lot of flaws I can find, most of which I hope to correct.   I have a feeling the pilot may have been a bit of an extrovert, if he chose the scheme.
Cheers.
Dal.
Offline Dal Gavan
« Reply #37 on: August 26, 2012, 08:52:47 PM »
G'day.
Back from the farm, where I fixed up the bottom of the Pfalz.  Most of it, anyway- I left my putty here and made the choice to get on with it, rather than wait until the next trip.  So the seams where the lower rear part of the wing joins the fuselage are there- and there they'll stay.  I didn't try to spray the cross on the wing, I can do that next time and I'll know the paint is completely dry before masking.  Or I'll mask and brush paint it here.  The wing looks blotchier than the photo's shows, the Mr Softener I used to help lift the decal remains may be the cause.  In any case it will be toned down with weathering (I hope).  At least the rear fuselage came up well and it only took a minute to touch up the various feldgrau fittings.  This is a learning experience, and I'll do better with the Spad and later models, I hope.
When I got home I rigged the tail.  It was a lot easier than I'd feared and I'm fairly happy with how things turned out.  I've used a slightly different method to those I've read about, as I was trying to emphasise the use of turnbuckles.  The fences on a farm mean you get very familiar with using turnbuckles..... :P  They look larger than I'd really like them to look and I'm afraid the swaging clips don't look as good I'd hoped, but they did make the rigging fairly easy to tension and don't look too bad at three feet.  The lines have been painted with Mr Metal Colour dark iron and don't look nearly as "lumpy" as they do in the photo' below.  Anyway, you can see for yourself.
Next up is a bit of dot filtering and a couple of washes to add some depth to the details and to (lightly) stain the lower fuselage.  The photo's I've seen of this aircraft show it looking very clean, but close-ups of the fuselage show some dings in the fuselage, on the silbergrau paint.  I wonder if these photo's show the 'plane cleaned up and after having the red and blue added, perhaps when they changed the style of cross?  After that will be a coat of "One-Go" (Aussie Future) and then semi-goss, before I try the pastel weathering technique that many here use so well.
As usual, all comments, suggestions and corrections will be gratefully received.
Cheers.
Dal.
« Last Edit: August 27, 2012, 07:43:58 AM by Des »
« Reply #38 on: August 26, 2012, 11:38:45 PM »
Dal,
    Wonderful results on the cables. Swaging clips (??), your own design/build or a commercial product? They really look the part and I'd gladly steal the idea with your permission.................. ::) Good luck with the Pastel stage; I'll be watching that closely as well.
Offline kornbeef
« Reply #39 on: August 27, 2012, 02:39:43 AM »
Dal, some gorgeous work there indeed.
Keith
« Reply #40 on: August 27, 2012, 03:03:37 AM »
   Dal,
Fantastic update my friend. Outstanding rigging to date. She's shaping up to be one First Class project.
Offline Dal Gavan
« Reply #41 on: August 27, 2012, 06:12:28 PM »
Thanks, Gents.
I learn something new every time I touch this kit.  Such as don't leave the open bottle of paint near the edge of the bench......
Lance, swaging clips (also called ferrules or sleeves) are used on wire rope, and sometimes single-strand wire, to trap the running end of the rope when you make an eye, using a thimble or yoke.  <snipped- lapsed into instructor-speak.
I tried to replicate it using 0.5mm wire crushed with round-nosed pliers, but it's not working for me- the clips don't match the photo's or Bertl's old warhorse- they're too short and wide.  The Germans may have wire-wound and shrouded the wire, which would give that long, thin look.  I'll have to experiment a bit more..
Feel free to use it if you want to, mate- you've given me enough tips with your builds.
Youse blokes realise that if youse weren't inspiring me to lift me game and try new techniques then I'd have finished this bleedin' kit 12 months ago, don't yers?   It's all your fault!
;D
Cheers.
Dal.
« Last Edit: August 28, 2012, 06:07:53 AM by Dal Gavan »
Offline Pete Nottingham
« Reply #42 on: August 27, 2012, 09:48:56 PM »
Great job Dal, a most impressive looking Pfalz with lovely rigging.
Pete.
« Reply #43 on: August 27, 2012, 10:47:03 PM »
Thanks for the info Dal. Some of the photos I've studied indicate that you are probably correct on the "wire wound" and/or "shrouded" ends on the rigging wire. I'm going to do a mini-search later today to confirm. I also note that a lot of the TVAL Albie close ups indicate that the wires are simply wound back on themselves.
Offline Jim52
« Reply #44 on: August 27, 2012, 11:04:59 PM »
Gents,
         A lot of the ends of the wire rope had a loop splice in them
as you would with a regular fiber rope. I think that's what gives that
long tapered look.
Jim
